* Description
* This sketch shows how value can be pushed from NodeMCU to the Blynk App.
* Input
* D2 : NODEMCU/ESP8266 Digital Pin 4
* Output
* V0 : Blynk Virtual Pin 0 : Value Display widget attached to V0
* V1 : Blynk Virtual Pin 1 : Value Display widget attached to V1
// Import Libraries
#include "DHT.h" // including the library of DHT11 temperature and humidity sensor
// Constants
#define BLYNK_PRINT Serial // not sure if should be on top !?
//#define DHTTYPE DHT11 // DHT 11
//#define DHTTYPE DHT22 // DHT 22, AM2302, AM2321
//#define DHTTYPE DHT21 // DHT 21, AM2301
#define DHTPIN 4 // NodeMcu Digital Pin 4 D2 Arduino Crossover
char auth[] = "AUTHTOKEN"; // Blynk Auth Token
char ssid[] = "SSID"; // Your WiFi credentials (SSID)
char pass[] = "PASSWORD"; // Your WiFi credentials (PASSWORD)
// Objects
DHT dht(DHTPIN, DHTTYPE); // Set DHT Object with Digital Pin and Senor Type
// Functions
void sendSensor() {
// This function sends Arduino's up time every 5 seconds to Virtual Pin (5).
float humidity = dht.readHumidity();
float temperature = dht.readTemperature(); // or dht.readTemperature(true) for Fahrenheit
if (isnan(humidity) || isnan(temperature)) {
return;
Blynk.virtualWrite(V0, humidity);
Blynk.virtualWrite(V1, temperature);
// Main
dht.begin();
// Setup a function to be called every 60 seconds
timer.setInterval(60000L, sendSensor);
