I restarted the server several times (in the same way I do when I upgrade it) and no issues with sharing.
Here is the log file for a restart.
04:42:04.848 INFO - myemailaddress Blynk-app joined. Version : android-0
05:51:54.887 INFO - myemailaddress Blynk-app joined. Version : android-0
06:18:46.816 INFO - myemailaddress Blynk-app joined. Version : android-0
06:25:18.185 DEBUG- Using SLF4J as the default logging framework
06:25:18.226 INFO - Using data dir '/home/pi/Blynk/BlynkData'
06:25:18.352 DEBUG- -Dio.netty.noUnsafe: false
06:25:18.354 DEBUG- Java version: 8
06:25:18.360 DEBUG- sun.misc.Unsafe.theUnsafe: available
06:25:18.365 DEBUG- sun.misc.Unsafe.copyMemory: available
06:25:18.369 DEBUG- java.nio.Buffer.address: available
06:25:18.372 DEBUG- direct buffer constructor: available
06:25:18.376 DEBUG- java.nio.Bits.unaligned: available, false
06:25:18.377 DEBUG- jdk.internal.misc.Unsafe.allocateUninitializedArray(int): unavailable prior to Java9
06:25:18.377 DEBUG- java.nio.DirectByteBuffer.<init>(long, int): available
06:25:18.377 DEBUG- sun.misc.Unsafe: available
06:25:18.380 DEBUG- -Dio.netty.tmpdir: /tmp (java.io.tmpdir)
06:25:18.380 DEBUG- -Dio.netty.bitMode: 32 (sun.arch.data.model)
06:25:18.387 DEBUG- -Dio.netty.noPreferDirect: false
06:25:18.387 DEBUG- -Dio.netty.maxDirectMemory: 249364480 bytes
06:25:18.388 DEBUG- -Dio.netty.uninitializedArrayAllocationThreshold: -1
06:25:18.393 DEBUG- java.nio.ByteBuffer.cleaner(): available
06:25:18.413 DEBUG- Starting reading user DB.
06:25:21.915 DEBUG- Reading user DB finished.
06:25:21.915 INFO - Region : local. Host : 192.168.1.210.
06:25:22.244 DEBUG- -Dio.netty.eventLoopThreads: 8
06:25:22.386 DEBUG- -Dio.netty.noKeySetOptimization: false
06:25:22.386 DEBUG- -Dio.netty.selectorAutoRebuildThreshold: 512
06:25:22.432 DEBUG- org.jctools-core.MpscChunkedArrayQueue: available
06:25:22.460 TRACE- instrumented a special java.util.Set into: sun.nio.ch.EPollSelectorImpl@1250572
06:25:22.467 TRACE- instrumented a special java.util.Set into: sun.nio.ch.EPollSelectorImpl@36eb5f
06:25:22.468 TRACE- instrumented a special java.util.Set into: sun.nio.ch.EPollSelectorImpl@1e2a9e
06:25:22.469 TRACE- instrumented a special java.util.Set into: sun.nio.ch.EPollSelectorImpl@1a36558
06:25:22.469 TRACE- instrumented a special java.util.Set into: sun.nio.ch.EPollSelectorImpl@12872e1
06:25:22.470 TRACE- instrumented a special java.util.Set into: sun.nio.ch.EPollSelectorImpl@910148
06:25:22.471 TRACE- instrumented a special java.util.Set into: sun.nio.ch.EPollSelectorImpl@156875e
06:25:22.472 TRACE- instrumented a special java.util.Set into: sun.nio.ch.EPollSelectorImpl@14bac49
06:25:22.473 TRACE- instrumented a special java.util.Set into: sun.nio.ch.EPollSelectorImpl@1d07cbb
06:25:22.602 DEBUG- -Dio.netty.leakDetection.level: disabled
06:25:22.603 DEBUG- -Dio.netty.leakDetection.targetRecords: 4
06:25:22.615 DEBUG- Loaded default ResourceLeakDetector: io.netty.util.ResourceLeakDetector@bf4075
06:25:23.517 DEBUG- Default protocols (JDK): [TLSv1.2, TLSv1.1, TLSv1]
06:25:23.518 DEBUG- Default cipher suites (JDK): [TLS_ECDHE_ECDSA_WITH_AES_256_GCM_SHA384, TLS_ECDHE_ECDSA_WITH_AES_128_GCM_SHA256, TLS_ECDHE_RSA_WITH_AES_128_GCM_SHA256, TLS_ECDHE_RSA_WITH_AES_128_CBC_SHA, TLS_ECDHE_RSA_WITH_AES_256_CBC_SHA, TLS_RSA_WITH_AES_128_GCM_SHA256, TLS_RSA_WITH_AES_128_CBC_SHA, TLS_RSA_WITH_AES_256_CBC_SHA]
06:25:23.587 TRACE- instrumented a special java.util.Set into: sun.nio.ch.EPollSelectorImpl@1e360a
06:25:23.588 TRACE- instrumented a special java.util.Set into: sun.nio.ch.EPollSelectorImpl@1a3f27a
06:25:23.588 TRACE- instrumented a special java.util.Set into: sun.nio.ch.EPollSelectorImpl@d75e99
06:25:23.589 TRACE- instrumented a special java.util.Set into: sun.nio.ch.EPollSelectorImpl@14751b3
06:25:23.590 TRACE- instrumented a special java.util.Set into: sun.nio.ch.EPollSelectorImpl@1a8937
06:25:23.591 TRACE- instrumented a special java.util.Set into: sun.nio.ch.EPollSelectorImpl@6e95ec
06:25:23.591 TRACE- instrumented a special java.util.Set into: sun.nio.ch.EPollSelectorImpl@af26ee
06:25:23.592 TRACE- instrumented a special java.util.Set into: sun.nio.ch.EPollSelectorImpl@1d83fc1
06:25:23.665 DEBUG- -Dio.netty.threadLocalMap.stringBuilder.initialSize: 1024
06:25:23.665 DEBUG- -Dio.netty.threadLocalMap.stringBuilder.maxSize: 4096
06:25:23.751 DEBUG- -Dio.netty.allocator.numHeapArenas: 2
06:25:23.752 DEBUG- -Dio.netty.allocator.numDirectArenas: 2
06:25:23.752 DEBUG- -Dio.netty.allocator.pageSize: 8192
06:25:23.752 DEBUG- -Dio.netty.allocator.maxOrder: 11
06:25:23.752 DEBUG- -Dio.netty.allocator.chunkSize: 16777216
06:25:23.752 DEBUG- -Dio.netty.allocator.tinyCacheSize: 512
06:25:23.752 DEBUG- -Dio.netty.allocator.smallCacheSize: 256
06:25:23.753 DEBUG- -Dio.netty.allocator.normalCacheSize: 64
06:25:23.753 DEBUG- -Dio.netty.allocator.maxCachedBufferCapacity: 32768
06:25:23.753 DEBUG- -Dio.netty.allocator.cacheTrimInterval: 8192
06:25:23.753 DEBUG- -Dio.netty.allocator.useCacheForAllThreads: true
06:25:23.804 DEBUG- -Dio.netty.allocator.type: pooled
06:25:23.805 DEBUG- -Dio.netty.threadLocalDirectBufferSize: 65536
06:25:23.805 DEBUG- -Dio.netty.maxThreadLocalCharBufferSize: 16384
06:25:24.229 INFO - Initializing gmail smtp mail transport. Username : mancave@gmail.com. SMTP host : smtp.gmail.com:587
06:25:24.606 INFO - Didn't find custom user certificates.
06:25:24.614 INFO - Didn't find Let's Encrypt certificates.
06:25:24.614 WARN - You didn't specified 'server.host' or 'contact.email' properties in server.properties file. Automatic certificate generation is turned off. Please specify above properties for automatic certificates retrieval.
06:25:24.615 WARN - ATTENTION. Server certificate paths (cert : '/home/pi/Blynk', key : '/home/pi/Blynk') not valid. Using embedded server certs and one way ssl. This is not secure. Please replace it with your own certs.
06:25:25.669 DEBUG- -Dio.netty.buffer.bytebuf.checkAccessible: true
06:25:25.670 DEBUG- Loaded default ResourceLeakDetector: io.netty.util.ResourceLeakDetector@9b0314
06:25:25.862 DEBUG- hard.socket.idle.timeout = 15
06:25:25.914 DEBUG- app.socket.idle.timeout = 600
06:25:26.526 DEBUG- hard.socket.idle.timeout = 15
06:25:26.602 DEBUG- -Dio.netty.processId: 9079 (auto-detected)
06:25:26.617 DEBUG- -Djava.net.preferIPv4Stack: false
06:25:26.617 DEBUG- -Djava.net.preferIPv6Addresses: false
06:25:26.622 DEBUG- Loopback interface: lo (lo, 0:0:0:0:0:0:0:1%lo)
06:25:26.625 DEBUG- /proc/sys/net/core/somaxconn: 128
06:25:26.633 DEBUG- -Dio.netty.machineId: b8:27:eb:ff:fe:a4:07:17 (auto-detected)
06:25:26.821 INFO - Hardware plain tcp/ip server listening at 8442 port.
06:25:26.829 INFO - Hardware SSL server listening at 8441 port.
06:25:26.833 INFO - Application server listening at 8443 port.
06:25:26.835 INFO - HTTP API and WebSockets server listening at 6123 port.
06:25:26.839 INFO - HTTPS API, WebSockets and Admin page server listening at 9443 port.
06:25:26.841 INFO - Mqtt hardware server listening at 8440 port.
06:25:30.087 DEBUG- -Dio.netty.recycler.maxCapacityPerThread: 32768
06:25:30.087 DEBUG- -Dio.netty.recycler.maxSharedCapacityFactor: 2
06:25:30.087 DEBUG- -Dio.netty.recycler.linkCapacity: 16
06:25:30.087 DEBUG- -Dio.netty.recycler.ratio: 8
06:25:30.205 TRACE- Incoming LoginMessage{id=1, command=Login, length=32, body='545613a97015468dab1c4ae3c7ce85b6'}
06:25:30.205 TRACE- Incoming LoginMessage{id=1, command=Login, length=32, body='a6a6e187e6c24f78a7bd88f2d2853959'}
06:25:30.205 TRACE- Incoming LoginMessage{id=1, command=Login, length=32, body='024902f3a1e4405fa9de3b261760ac89'}
06:25:30.206 TRACE- Incoming LoginMessage{id=1, command=Login, length=32, body='43b9b0f8e9d0476c82146f0ea8c2bb10'}
06:25:30.206 TRACE- Incoming LoginMessage{id=1, command=Login, length=32, body='06cf00aa866e4871b34813326660b95d'}
06:25:30.206 TRACE- Incoming LoginMessage{id=1, command=Login, length=32, body='30df908db04c4633b4d45f295d180b5a'}
06:25:30.271 DEBUG- Re registering hard channel. [id: 0xc53367d7, L:/192.168.1.210:8442 - R:/192.168.1.193:49169]
06:25:30.271 TRACE- Creating unique session for user: UserKey{email='myemailaddress', appName='Blynk'}
06:25:30.271 DEBUG- completeLogin. [id: 0x7f9e696f, L:/192.168.1.210:8442 - R:/192.168.1.194:9232]
06:25:30.271 DEBUG- Re registering hard channel. [id: 0xf6b4d9fb, L:/192.168.1.210:8442 - R:/192.168.1.190:8237]
06:25:30.272 DEBUG- Re registering hard channel. [id: 0xd11f9db5, L:/192.168.1.210:8442 - R:/192.168.1.192:28567]
06:25:30.275 DEBUG- Re registering hard channel. [id: 0xce76cba8, L:/192.168.1.210:8442 - R:/192.168.1.195:19570]
06:25:30.277 DEBUG- Re registering hard channel. [id: 0x421a6e1c, L:/192.168.1.210:8442 - R:/192.168.1.191:31146]
06:25:30.412 TRACE- Connected device id 79820, dash id 2
06:25:30.413 INFO - myemailaddress hardware joined.
06:25:30.414 DEBUG- completeLogin. [id: 0xc53367d7, L:/192.168.1.210:8442 - R:/192.168.1.193:49169]
06:25:30.416 TRACE- Connected device id 41350, dash id 2
06:25:30.416 INFO - myemailaddress hardware joined.
06:25:30.417 DEBUG- completeLogin. [id: 0xf6b4d9fb, L:/192.168.1.210:8442 - R:/192.168.1.190:8237]
06:25:30.418 TRACE- Connected device id 0, dash id 2
06:25:30.419 INFO - myemailaddress hardware joined.
06:25:30.419 DEBUG- completeLogin. [id: 0xd11f9db5, L:/192.168.1.210:8442 - R:/192.168.1.192:28567]
06:25:30.420 TRACE- Connected device id 67085, dash id 2
06:25:30.421 INFO - myemailaddress hardware joined.
06:25:30.421 DEBUG- completeLogin. [id: 0x421a6e1c, L:/192.168.1.210:8442 - R:/192.168.1.191:31146]
06:25:30.422 TRACE- Connected device id 53197, dash id 2
06:25:30.422 INFO - myemailaddress hardware joined.
06:25:30.423 DEBUG- completeLogin. [id: 0xce76cba8, L:/192.168.1.210:8442 - R:/192.168.1.195:19570]
06:25:30.424 TRACE- Connected device id 60095, dash id 2
06:25:30.424 INFO - myemailaddress hardware joined.
06:25:30.426 TRACE- Incoming BlynkInternalMessage{id=2, command=Internal, length=73, body='ver 0.4.10 h-beat 10 buff-in 1024 dev ESP8266 build Oct 29 2017 17:08:45 '}
06:25:30.427 TRACE- Info command. heartbeat interval 10
06:25:30.430 DEBUG- Changing read timeout interval to 23
06:25:30.441 TRACE- Incoming BlynkInternalMessage{id=2, command=Internal, length=73, body='ver 0.4.10 h-beat 10 buff-in 1024 dev Arduino build Oct 29 2017 16:56:09 '}
06:25:30.442 TRACE- Info command. heartbeat interval 10
06:25:30.442 DEBUG- Changing read timeout interval to 23
06:25:30.445 TRACE- Incoming BlynkInternalMessage{id=2, command=Internal, length=73, body='ver 0.4.10 h-beat 10 buff-in 1024 dev ESP8266 build Nov 27 2017 16:47:35 '}
06:25:30.445 TRACE- Info command. heartbeat interval 10
06:25:30.446 DEBUG- Changing read timeout interval to 23
06:25:30.462 TRACE- Incoming BlynkInternalMessage{id=2, command=Internal, length=73, body='ver 0.4.10 h-beat 10 buff-in 1024 dev ESP8266 build Nov 30 2017 18:44:12 '}
06:25:30.462 TRACE- Info command. heartbeat interval 10
06:25:30.462 DEBUG- Changing read timeout interval to 23
06:25:30.465 TRACE- Incoming BlynkInternalMessage{id=2, command=Internal, length=73, body='ver 0.4.10 h-beat 10 buff-in 1024 dev ESP8266 build Dec 2 2017 11:18:26 '}
06:25:30.466 TRACE- Info command. heartbeat interval 10
06:25:30.466 DEBUG- Changing read timeout interval to 23
06:25:30.529 TRACE- Incoming BlynkInternalMessage{id=2, command=Internal, length=72, body='ver 0.5.0 h-beat 10 buff-in 1024 dev Arduino build Jan 13 2018 15:05:28 '}
06:25:30.530 TRACE- Info command. heartbeat interval 10
06:25:30.530 DEBUG- Changing read timeout interval to 23
06:25:40.423 TRACE- Incoming PingMessage{id=3, command=Ping, length=0, body=''}
