Several webhooks at application
Hi.
I’ve a code of simple program, when U’ll press the button - U’ll receive a notification via Telegram by webhook.
But what should I do, if I’ll need for example 10 different notifications at the same program, should I use 10 webhooks or maybe I can go by another way.
Webhook link: https://api.telegram.org/botxxxxxxxxxx:AAHSbPjh3woP6Xgi9x2vMYzdJ5_MpZFi3d0/sendMessage?chat_id=xxxxxxx&text=Test
   >  #define BLYNK_PRINT Serial
>     #include <ESP8266WiFi.h>
>     #include <BlynkSimpleEsp8266.h>
>     // You should get Auth Token in the Blynk App.
>     // Go to the Project Settings (nut icon).
>     char auth[] = "";
>     // Your WiFi credentials.
>     // Set password to "" for open networks.
>     char ssid[] = "";
>     char pass[] = "";
>     int value;
>     BLYNK_WRITE(V5)
>     value =param.asInt();
>     if(value == 1)
>      Blynk.virtualWrite(V10, value = 0);
>     void setup()
>       Serial.begin(115200);
>       // Debug console
>       //Serial.begin(9600);
>       Blynk.begin(auth, ssid, pass);
>     void loop()
>       Blynk.run();
@DoMoney please edit your post, using the pencil icon at the bottom, and add triple backticks at the beginning and end of your code so that it displays correctly.
Blockquotes are not the correct way to post code.
