Hi guys, I have several ESP8266s connected to the same Wi-Fi network, measuring the temperature and humidity of several rooms and controlling the on and off of various equipment in each room.
I would like to know how I can control all the ESP8266 boards and even an aduino that I have at the same time in an isma app, without having to make an app for each board … which is a bummer.
I don’t really know how to do it since I only have one token.
Thank you very much in advance.
A greeting.
You simply stop your existing project, click the Nut icon and hit “+ New Device”
Choose the correct type of device and connection type and give it a meaningful name. The device will then get a new Auth code, and when you add a widget to the project you can choose which device the widget relates to - but take care because your first device is the default, so you can waste many hours working out why your widget doesn’t work correctly with your device.
You are a monster. Thanks a lot. I’m going to get to it right away.
Haha Very good!
