I am having several issues with Blynk 2.0. Maybe someone can point me in the right direction. First, let me say that my firmware worked just fine in the legacy app. I am connected to my device with 2.0 and have the template information and correct auth token.
First, I have a Pro plan. In that plan it states that support is available via email 1-3 business days. Who do I email? I cannot locate that information.
I created a template during the free trial. Using that template I have the following issues;
Map widget-although I can see in the serial data that my button pushes are working correctly and providing GPS data, nothing happens with the map. Out of desperation, I deleted the map widget from both my template and my app. Now that I have done that, I can no longer add the map widget back to my app-says :“not available”
I have a VLED assigned to the cellular radio on my device. It is supposed to update when the radio is either ON or OFF. Yesterday, when I shut the radio off the VLED updated to OFF but now refuses to update to ON. The radio is ON and I can carry out other functions so I know I am connected and this is verified also in my data log. I have deleted and added the LED widget numerous times as well as flashed the firmware several times in hopes that the situation resolved itself, it has not.
In the device/dashboard I can see switch widgets updating when I toggle them in the app. However, now I have one switch that although it works in the app, it no longer updates in the dashboard.
I am tempted to just delete the entire template and just start over, I thought I would start here first.
By updating the mobile app, I was able to load the map widget. However, although my code worked flawlessly in the legacy app, I am still not able to make it function with Blynk 2.0
This is now working. By deleting it and adding it back several times, it finally started working correctly
This was a V0 issue and yes, it now works correctly.
I also have an issue with the slider. My values are set to 5 and 15 on the web dashboard. When I am on the Device Dashboard those values are retained only so long as I do not navigate away from that page. If I do, the value changes to 1-15. Further, if I move the slider widget on the mobile app the result is the same as the navigation error noted above. Pavel is aware of this issue and has screen captures etc. I do not know where he is at with it as I have not heard from him since the 5th. But he informed me then that it will be fixed soon as possible.
So, my outstanding issues are with the map and slider. I also sent you a DM related to a previous issue. Not sure if you ever saw it?
Thanks very much for your reply. I know you guys are busy
iOS, correct. Yes, data stream is assigned. I have emailed you screen shots, code and video which should also help explain your last question. Let me know if you need more information and thank you very much
Data stream for slider was incorrectly set at 0-1. Changing to the required settings of 5-15 and saving them, solved the slider issue. A simple solution and one I completely missed. I am sure the map widget will end up the same way
Thank you
