setInterval ? conflict?
In my project, I have a temperature sensor and a push button to control an LED
The problem, when the temperature is sent every 5 seconds, I cannot turn on the led.
Looks like the two functions are in conflict, how to avoid this problem?
  timer.setInterval(100L, checkPhysicalButton);
  timer.setInterval(5000L, sendTemps);
Impossible to say from two lines of code.
#include <WiFi.h>
#include <WiFiClient.h>
#include <BlynkSimpleEsp32.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#define SCREEN_WIDTH 128 // OLED display width, in pixels
#define SCREEN_HEIGHT 64 // OLED display height, in pixels
#include <OneWire.h>
#define ONE_WIRE_BUS 23          // Your ESP8266 pin (ESP8266 GPIO 2 = WeMos D1 Mini pin D4)
char auth[] = "xxxxxxxxxx";
char ssid[] = "xxxxxxx";
char pass[] = "xxxxxxx";
// Set your LED and physical button pins here
const int ledPin = 18;
const int btnPin = 19;
void checkPhysicalButton();
int ledState = LOW;
int btnState = HIGH;
// Every time we connect to the cloud...
BLYNK_CONNECTED() {
  Blynk.syncVirtual(V2);
  // Alternatively, you could override server state using:
  //Blynk.virtualWrite(V2, ledState);
// When App button is pushed - switch the state
BLYNK_WRITE(V2) {
  ledState = param.asInt();
  digitalWrite(ledPin, ledState);
  if (digitalRead(btnPin) == LOW) {
    if (btnState != LOW) {
      // Toggle LED state
      ledState = !ledState;
      // Update Button Widget
    btnState = LOW;
    btnState = HIGH;
float roomTemperature;            // Room temperature in F
#define OLED_RESET     -1 // Reset pin # (or -1 if sharing Arduino reset pin)
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
#define NUMFLAKES     10 // Number of snowflakes in the animation example
#define LOGO_HEIGHT   16
#define LOGO_WIDTH    16
static const unsigned char PROGMEM logo_bmp[] =
{ B00000000, B11000000,
  B00000001, B11000000,
  B00000011, B11100000,
  B11110011, B11100000,
  B11111110, B11111000,
  B01111110, B11111111,
  B00110011, B10011111,
  B00011111, B11111100,
  B00001101, B01110000,
  B00011011, B10100000,
  B00111111, B11100000,
  B00111111, B11110000,
  B01111100, B11110000,
  B01110000, B01110000,
  B00000000, B00110000 };
  pinMode(ledPin, OUTPUT);
  pinMode(btnPin, INPUT_PULLUP);
  sensors.begin();                        // Starts the DS18B20 sensor(s).
  sensors.setResolution(10);              // More on resolution: http://www.homautomation.org/2015/11/17/ds18b20-how-to-change-resolution-9101112-bits/
 if(!display.begin(SSD1306_SWITCHCAPVCC, 0x3C)) {
    Serial.println(F("SSD1306 allocation failed"));
    for(;;); // Don't proceed, loop forever
  // Show initial display buffer contents on the screen --
  // the library initializes this with an Adafruit splash screen.
  display.display();
  delay(2000); // Pause for 2 seconds
  // Clear the buffer
  display.clearDisplay();
  // Show the display buffer on the screen. You MUST call display() after
  // drawing commands to make them visible on screen!
  display.display();
  // display.display() is NOT necessary after every single drawing command,
  // unless that's what you want...rather, you can batch up a bunch of
  // drawing operations and then update the screen all at once by calling
  // display.display(). These examples demonstrate both approaches...
  // Invert and restore display, pausing in-between
  timer.setInterval(9000L, sendTemps);
  // to avoid delay() function!
void sendTemps()
  sensors.requestTemperatures();                  // Polls the sensors.
  roomTemperature = sensors.getTempCByIndex(0);   // Stores temperature. Change to getTempCByIndex(0) for celcius.
  Blynk.virtualWrite(1, roomTemperature);         // Send temperature to Blynk app virtual pin 1.
  display.setTextSize(2); // Draw 2X-scale text
  display.setTextColor(WHITE);
  display.setCursor(10, 0);
  display.println(F("Salon :"));
  display.display();      // Show initial text
   display.setTextSize(1);             // Draw 2X-scale text
  display.print(roomTemperature);
  display.print("C");
  display.display();
  delay(100);
Don’t use delays with Blynk :stuck_out_tongue_winking_eye:
and you have to stage timers
because 9000 = 90*100
so at 9000, you have sendTemps and checkPhysicalButton execution at same time
try :
timer.setInterval(9030L, sendTemps);
If you mean that whist the sendTemps function is executing the physical button is unresponsive for 1.1 seconds then this is due to the two blocking delays at the end of the sendTemps function.
If you mean something else, it would be useful if you’d explain in more detail what your issue is.
you understood my problem very well @PeteKnight
Thank you @Blynk_Coeur I removed the delay, it works perfectly
