Hi All,
I´m working in a servo motor project using a esp8266 board with blynk app where the task is triggered at a certain hour using the timer widget. I wish the delay value could be defined from the app, so the servo turns at a specific value. These could be done using the input value widget? remember that I´m using the timer widget also.
Another alternative to achieve the same result is to have a fixed delay value, such as 500, but from the blynk app I could select a multiplier so the task is repeated by x2 x3 etc.
Thanks a lot.
BLYNK_WRITE(V5)
servo.write(70); //85 is more like a speed instead of an angle.
delay(500);
servo.write(80); //Stop
