Hello, im having a problem where when my servo that should constantly be running if above 30, stops for a split second and comes back.
I would be really thankfull if someone could help.
ESP 32
Android
Connected to hotspot
Blynk version: 2.27.29 android
Blynk Library: 1.0.0
#define SIGNAL_PIN_1 18
#define SIGNAL_PIN_2 19
#include <WiFi.h>
#include <WiFiClient.h>
#include <BlynkSimpleEsp32.h>
#include <DHT.h>
#include <ESP32_Servo.h>
char auth[] = "iaJuNNZhb1S820_WlNfPIiKZ8JdMQ4VI";
char ssid[] = "PAP Igor";
char pass[] = "12345678";
#define DHTPIN 13
#define DHTTYPE DHT11
DHT dht(DHTPIN, DHTTYPE);
Servo myservo;
int servoPin = 14;
int pos = 0;
void sendSensor()
float h = dht.readHumidity();
if (isnan(h) || isnan(t)) {
return;
Blynk.virtualWrite(V5, h);
Blynk.virtualWrite(V6, t);
void temperatura ()
if (dht.readTemperature() > 30) {
myservo.attach(servoPin);
myservo.write(180);
myservo.detach();
if (dht.readTemperature() > 50) {
Serial.println("Temperatura Alta");
Blynk.notify("Temperatura Alta");
delay(10000);
Serial.println("Temperatura Normal");
dht.begin();
timer.setInterval(100L, temperatura);
pinMode(SIGNAL_PIN_1, INPUT);
pinMode(SIGNAL_PIN_2, INPUT);
pinMode(14, OUTPUT);
if (digitalRead(SIGNAL_PIN_1) == HIGH) {
Serial.println("Movimento Patio");
Blynk.notify("Movimento Patio");
delay(10000);
Serial.println("Nada Patio");
if (digitalRead(SIGNAL_PIN_2) == HIGH) {
Serial.println("Movimento Jardim");
Blynk.notify("Movimento Jardim");
delay(10000);
Serial.println("Nada Jardim");
