* Description
* Controlling 2 servos over wifi using Blynk library and nodemcu (ESP8266)
* Input
* V0 : Blynk Virtual Pin 0 (I used vertical slider)
* V1 : Blynk Virtual Pin 1 (I used horizontal slider)
* Output
* V0 desired value as object (servoVertical) new angle
* V1 desired value as object (servoHorizontal) new angle
* Important
* Timer has been added to detach servo, this way servo motor will not force
* note that when slider(s) are touch(ed) servo(s) re-attach to set new angle
* There are two common types of servo:
* White - Red - Black wired servo
* Orange - Red - Brown wired servo
* If your servo has White - Red - Black wires, then connect it as follows
* White wire connects to Digital pin D4
* Black wire connects to GND pin
* Red wire connects to 3V3 pin
* If your servo has Orange - Red - Brown wires, then connect it as follows
* Orange wire connects to Digital pin D4.
* Brown wire connects to GND pin
// LIBRARIES //
#include <Servo.h>
// TOOLS //
// GLOBAL VARIABLES //
char auth[] = "AUTH";
char ssid[] = "SSID";
char pass[] = "SSIDPASSWORD";
const int DigitalPinD0 = 16;
const int DigitalPinD1 = 5;
// OBJECTS //
Servo servoVertical;
Servo servoHorizontal;
BLYNK_WRITE(V0) {
servoVertical.attach(DigitalPinD0);
servoVertical.write(param.asInt());
BLYNK_WRITE(V1) {
servoHorizontal.attach(DigitalPinD1);
servoHorizontal.write(param.asInt());
// CUSTOM FUNCTION //
void goDetach() {
servoVertical.detach();
servoHorizontal.detach();
// MAIN //
digitalWrite(LED_BUILTIN, HIGH);
timer.setInterval(10000L, goDetach);
I think that newcomers may struggle to follow your instructions to build this project themselves.
Your description of how to attach the servo (you only talk about one here) has the servo attached to pin D4, yet cour code uses pins D0 and D1.
D0 is actually a poor choice of pin, because if it’s pulled LOW on startup then it can put the NodeMCU into programming mode. See this topic for more details:
I understand that code may be too heavy, it seems I dont have the possibility to edit the code anymore…
thanks for the pin information I didn’t know aboout appropriate pin
* Description
* Input
* Output
* V0 desired value (servo angle)
* V1 desired value (servo angle)
// LIBRARIES //
#include <Servo.h>
// TOOLS //
BlynkTimer timer; // Import Blynk Timer from Blynk
char auth[] = "AUTH TOKEN";
const int DigitalPinD4 = 2; // pinmapping from nodemcu (ESP8266) to Arduino
const int DigitalPinD5 = 14;
// OBJECTS //
Servo servoVertical; // Define servoVertical Object
Servo servoHorizontal; // Define servoHorizontal Object
// INPUT //
BLYNK_WRITE(V0) { // incomming data from blynk virtual pin
servoVertical.attach(DigitalPinD4); // re-attach Object to digital pin
servoVertical.write(param.asInt()); // magical line that makes servo angle change
BLYNK_WRITE(V1) {
servoHorizontal.attach(DigitalPinD5);
void goDetach() { // function that detach servo (stop buzzing noise)
// MAIN //
Serial.begin(9600); // initialize serial communication
Blynk.begin(auth, ssid, pass); // initialize board wifi connection
servoVertical.attach(DigitalPinD4); // attach servo
digitalWrite(LED_BUILTIN, HIGH); // disable on board light
// use Blynk timer for 10000 ms (10sec) and then after run goDetach function
Blynk.run(); // launch application
timer.run(); // launch Blynk timer
