Server ports are busy
Hi, i want to host a local server and i am having trouble starting the jar file, the error says
Server ports are busy, most probably server already launched.
But it is not. I even restarted my computer.
Are there any other ports that we can use for starting it ? Or any other advice ?
Thank you.
Hi. Yes.
By default starts 7 servers on different ports:
1 server socket for SSL/TLS Hardware (8441 default)
1 server socket for plain tcp/ip Hardware (8442 default)
1 server socket for SSL/TLS Applications (8443 default)
1 server socket for HTTP API (8080 default)
1 server socket for HTTPS API (9443 default)
1 server socket for MQTT (8440 default)
1 server socket for Administration UI (7443 default)
You may find exactly problem in blynk.log file.
i put 81 as http api server its ok ?
Thank you for your quick answer.
It depends on your system. Some OSes restrict access to port like 81 without admin/root rights.
So what should i do to learn about what ports i should use for these 7 servers ?
thanks
It is up to you. Check log, see that port caused your trouble, change it. That’s it.
