Server Files on Raspberry Pi
Hey Blynkers!
Since iOS 10 came out I was wondering if I could make Siri control my Blynk projects. I found the Homebridge libraries for my Raspberry. which should connect the Raspberry to apple Homekit, which should connect Homekit to Blynk.
I never really tried setting up a local Blynk server, so this is my first time on that. I’ve got the server running, but i cannot login on it because it needs some files. The server.properties, mail.properties etc. These are not on my Raspberry. Do I need to create them by myself? Which ones do i need? What should they contain? So many questions!
I hope someone can help me!
Many thanks,
Bas Peter
Hello. You don’t need anything. All you need is just run jar file as stated in getting started - https://github.com/blynkkk/blynk-server#quick-local-server-setup
Yes i did that, i think.
when i enter
java -jar server-0.18.1.jar -dataFolder /home/pi/Blynk
and try to login on the server from my Phone, it says:
‘incorrect email or password. Try again’
then the blynk.log states:
ATTENTION. Certificate /home/pi and key /home/pi paths not falid… blahblahblah User not refistered.
What am i doing wrong?
Bas Peter
@BasPeter Press ‘Create new account’, and on the next page, above the green 'Sign up" box, there’s an icon. Press it. switch the slider to ‘Custom’ , and enter the ip address that has been assigned to your raspberry pi (you can see this in router settings) or you can find it from your pi with a couple google searches. Put that number in, leave the port number, and create a new account as you normally would. Your cloud acct won’t work here. Boom.
@BasPeter you didn’t create account on local server. So you have to create it.
Thanks guys!
I didnt know i had to do that
Have a nice day!
Bas Peter :grin:
