Thanks @Gunner but I’m not using a local server as I don’t trust my home server however, I could switch to it for testing purposes.
I don’t think the issue is with the code but… here it is:
#!/usr/bin/python3
#import libraries
from __future__ import print_function
import BlynkLib
from BlynkTimer import BlynkTimer
import time, json
import logging
import socket, errno
from datetime import datetime as dt
from mail import sendmail
from subprocess import check_output
from wgpio import * #from gpio.py script
VERSION = '2.0' #adapted to BlynkLib 2.0
# ** define colours needed **
#define BLYNK_GREEN "#23C48E"
#define BLYNK_BLUE "#04C0F8"
#define BLYNK_YELLOW "#ED9D00"
BLYNK_RED = '#D3435C'
#define BLYNK_DARK_BLUE "#5F7CD8"
#define PURPLE "#800080"
#define BLUE_VIOLET "#8A2BE2"
#define BROWN "#A52A2A"
#define DARK_CYAN "#008B8B"
#define DARK_MAGENTA "#8B008B"
#define DARK_ORCHID "#9932CC"
#define FUCHSIA "#FF00FF"
#define MAROON "#800000"
#define TEAL "#008080"
WHITE = '#FFFFFF'
BLACK = '#000000'
logging.basicConfig(filename='/home/pi/blynk.log',level=logging.DEBUG)
BLYNK_AUTH = '*****'
# Create BlynkTimer Instance
timer = BlynkTimer()
#virtual button pins
virbtns = [0,1,2,3,4,5,6,7,8,9,10]
# Initialize Blynk
#set variables
txt = "" #used for the email
set_hr = 9 #opening hour
set_min = 0 #opening minute
oldtime = 0 #used for opening time
#sblinds = 5 #blinds' det switch
#virtual leds micros
@blynk.ON('readV11')
def S_read_handler():
if(ledsOn(0)):
blynk.virtual_write(11, 0)
else:
blynk.virtual_write(11, 255)
@blynk.ON('readV12')
def XL_read_handler():
if(ledsOn(1)):
blynk.virtual_write(12, 0)
else:
blynk.virtual_write(12, 255)
@blynk.ON('readV13')
def XXL_read_handler():
if(ledsOn(2)):
blynk.virtual_write(13, 0)
else:
blynk.virtual_write(13, 255)
@blynk.ON('readV14')
def S1_read_handler():
if(ledsOn(3)):
blynk.virtual_write(14, 0)
else:
blynk.virtual_write(14, 255)
@blynk.ON('readV15')
def S2_read_handler():
if(ledsOn(4)):
blynk.virtual_write(15, 0)
else:
blynk.virtual_write(15, 255)
#updating virtual leds
def update_leds():
S_read_handler()
XL_read_handler()
XXL_read_handler()
S1_read_handler()
S2_read_handler()
@blynk.ON('V0')
def S1_write_handler(value):
if int(value[0]) == 1: # is the button pressed?
relayOn(0)
@blynk.ON('V1')
def S2_write_handler(value):
relayOn(1)
@blynk.ON('V2')
def S_write_handler(value):
relayOn(2)
@blynk.ON('V3')
def XL_write_handler(value):
relayOn(3)
@blynk.ON('V4')
def XXL_write_handler(value):
relayOn(4)
@blynk.ON('V5')
def sirena_write_handler(value):
relayOn(5)
btnStatus = 0
@blynk.ON('V16')
def btn_handler(value):
global btnStatus
btnStatus = int(value[0])
if btnStatus == 1:
blynk.set_property(6, 'offLabel', 'Activado')
blynk.set_property(6, 'offColor', WHITE)
blynk.set_property(6, 'offBackColor', BLYNK_RED)
else:
blynk.set_property(6, 'offLabel', 'Desactivado')
blynk.set_property(6, 'offColor', BLACK)
blynk.set_property(6, 'offBackColor', WHITE)
@blynk.ON('V6')
def blinds_write_handler(value):
if (int(value[0]) == 1 and btnStatus == 1):
relayOn(6)
@blynk.ON('V7')
def cx_write_handler(value):
relayOn(7)
@blynk.ON('V8')
def door_write_handler(value):
relayOn(8)
@blynk.ON('V9')
def lights_write_handler(value):
relayOn(9)
@blynk.ON('V10')
def wifi_write_handler(value):
relayOn(10)
@blynk.ON('readV18')
def get_external_ip():
fname = "/home/pi/data/data.json"
f = open(fname, "r")
data = json.load(f)
ext_ip = data["ext_ip"]["ext_ip"]
f.close()
blynk.virtual_write(18, ext_ip)
@blynk.ON('readV19')
def cpu_temp():
cmd = 'vcgencmd measure_temp'
t = check_output(cmd, shell = True).decode("utf-8")
t = t.rstrip('\n\r')
t = t.replace('temp=','')
t = t.replace("'C",'')
#t = t + 'ºC'
blynk.virtual_write(19, t)
@blynk.ON('readV17')
def rpi_uptime():
#get board total uptime
cmd = 'uptime -p'
t = t.replace('up','')
#t = t.replace('day','d')
#t = t.replace('days','d')
#t = t.replace('hour','hr')
#t = t.replace('hours','hr')
#t = t.replace('minutes','m')
#t = t.replace(',',' ')
# this widget will show uptime..
blynk.virtual_write(17, t)
@blynk.ON("connected")
def blynk_connected():
print("Updating leds values from the server...")
blynk.sync_virtual(11,12,13,14,15)
def open_blinds():
global oldtime, txt
t = time.localtime()
newtime = t.tm_min
if(t.tm_hour == set_hr and t.tm_min == set_min and not (oldtime == newtime)):
txt = "Persiana abierta a las "
txt += time.strftime("%H:%M:%S")
relayOn(6) #open blinds
if(sendmail(txt)):
print('Email sent - open_blinds')
oldtime = newtime
def checkAC():
global txt, emailsent
if(ACcheck() == 1):
txt = "No hay electricidad en la tienda - hora: "
if(sendmail(txt)):
print('Email sent - checkAC')
#activate timers
timer.set_interval(2, update_leds) #update virtual leds 2 secs
timer.set_interval(14, open_blinds) #check for opening time 15 secs
timer.set_interval(61, rpi_uptime) #update uptime display 1 minute
timer.set_interval(120, cpu_temp) #check cpu temperature 20m
timer.set_interval(900, checkAC) #check for AC every 15m
timer.set_interval(1803, get_external_ip) #check for external ip 30 minutes
if __name__ == "__main__":
init() #run once from wgpio.py
while True:
try:
blynk.run()
timer.run()
#machine.idle()
except socket.error as e:
if(e.errno != errno.EPIPE):
logging.exception("msg from blynkmain @ " + str(dt.now()))
raise
blynk.connect()
