Serial monitor shows Connecting to blynk.cloud:80 - Login timeout
Hi everyone. I’m using ESP32 DevKit V1 for my final year project and there seems to be a problem when connecting to the blynk.
I have read previous topics on how to solve this issue, and I have done all the things that have been suggested but still no solution. I have changed my connection from home wifi to my personal hotspot as i thought it may be less secure, but it doesnt change anything.
#define BLYNK_TEMPLATE_ID "TMPL6L6eS65OL"
#define BLYNK_TEMPLATE_NAME "Temperature and Humidity Monitoring"
#define BLYNK_AUTH_TOKEN "Nm4_-wCYC_JUekAk87TYD5589y4UFj60"
#include <WiFi.h>
#include <BlynkSimpleEsp32.h>
#include <DHT.h>
char ssid[] = "xxxxxxx";  // type your wifi name
char pass[] = "xxxxxxxx";  // type your wifi password
#define DHTPIN 27
#define DHTTYPE DHT11
DHT dht(DHTPIN, DHTTYPE);
void sendSensor()
  float h = dht.readHumidity();
  if (isnan(h) || isnan(t)) {
    return;
    Blynk.virtualWrite(V1, t);
    Blynk.virtualWrite(V2, h);
    Serial.print("Temperature : ");
    Serial.print(t);
    Serial.print("    Humidity : ");
    Serial.println(h);
  dht.begin();
came out like this
18:34:18.057 -> [1663] Connected to WiFi
18:34:18.057 -> [1663] IP: 192.168.100.114
18:34:18.057 ->     ___  __          __
18:34:18.134 ->    / _ )/ /_ _____  / /__
18:34:18.134 ->   / _  / / // / _ \/  '_/
18:34:18.176 ->  /____/_/\_, /_//_/_/\_\
18:34:18.176 ->         /___/ v1.3.2 on ESP32
18:34:18.247 ->
18:34:18.247 ->  #StandWithUkraine    https://bit.ly/swua
18:34:18.247 ->
18:34:18.247 ->
18:34:18.247 -> [1908] Connecting to blynk.cloud:80
18:34:24.346 -> [7949] Login timeout
18:34:24.346 -> [7951] Connecting to blynk.cloud:80
18:34:30.387 -> [13978] Login timeout
18:34:30.387 -> [13980] Connecting to blynk.cloud:80
18:34:36.265 -> [19910] Connecting to blynk.cloud:80
18:34:42.342 -> [25950] Login timeout
18:34:42.342 -> [25952] Connecting to blynk.cloud:80
18:34:48.366 -> [31974] Login timeout
18:34:48.366 -> [31976] Connecting to blynk.cloud:80
18:34:54.286 -> [37912] Connecting to blynk.cloud:80
18:35:00.327 -> [43932] Login timeout
Some info on what you’ve tried, and the results that you saw would be helpful, otherwise we’ll waste time suggesting stuff you’ve already tried.
