I am using Blynk App in my Android OS and using Arduino IDE 1.8.9. I am using NODEMCU wifi module.
I want my onboard LED to get on/off as per the code. The code is successfully uploaded to the NODEMCU wifi board but when i open the serial monitor, the output shows
[19683] connecting to ndtv
where ndtv is my wifi ssid. My baud rate is 9600 on the serial monitor as well as my code. I changed it to 115200 but same output shows on the serial monitor. It does not gets connected. Need help. Thanks
Please be sure to select the right ESP8266 module
in the Tools -> Board menu!
char auth[] = "9d276aafb0d94f3aacd793b805fef520";
char ssid[] = "ndtv";
char pass[] = "123678";
