Serial Blynk
. Add details :
• Hardware model + communication type. : Arduino Mega Serial
Library 1.0.0
/* Download latest Blynk library here:
    Follow us:                  http://www.fb.com/blynkapp
                                http://twitter.com/blynk_app
  This sketch shows how to read values from Virtual Pins
  App project setup:
    Slider widget (0...100) on Virtual Pin V1
#define BLYNK_PRINT Serial1
// in Blynk app writes values to the Virtual Pin V1
BLYNK_WRITE(V1)
  // process received value
  Serial1.begin(9600);
  Blynk.begin(Serial, auth);
I am Getteing this
In file included from C:\Users\dell\OneDrive\Documents\Arduino\libraries\Blynk\src/Blynk/BlynkApi.h:38:0,
                 from C:\Users\dell\OneDrive\Documents\Arduino\libraries\Blynk\src/BlynkApiArduino.h:14,
                 from C:\Users\dell\OneDrive\Documents\Arduino\libraries\Blynk\src/Adapters/BlynkSerial.h:18,
                 from C:\Users\dell\OneDrive\Documents\Arduino\libraries\Blynk\src/BlynkSimpleStream.h:18,
                 from C:\Users\dell\OneDrive\Documents\Arduino\sketch_jul09a\sketch_jul09a.ino:31:
C:\Users\dell\OneDrive\Documents\Arduino\libraries\Blynk\src/Blynk/BlynkConsole.h:20:10: fatal error: functional: No such file or directory
 #include <functional>
compilation terminated.
exit status 1
Error compiling for board Arduino Mega or Mega 2560.
Invalid library found in C:\Users\dell\OneDrive\Documents\Arduino\libraries\ArduinoJson: no headers files (.h) found in C:\Users\dell\OneDrive\Documents\Arduino\libraries\ArduinoJson
If this is meant for use with Blynk 0.1 then downgrade to Blynk library version 0.6.1
new blynk
No Template ID and name in your sketch!
Read this:
You’ll probably need to edit the Blynk USB script to use the new Blynk server too.
added template id and already followedc steps in blynkyoutube tutorial
Is that a tutorial written for Blynk 2.0 ?
Is your compiler error fixed now then?
no. it was uploaded n 2017
no soln
I have no idea what this means in practice.
Did you follow the link I provided?
Did you either edit your existing BlynkConsole.h file, or install the pre-release library?
What compiler messages are you getting now?
What changes do you intend to make to the USB script to make it Blynk 2.0 compliant?
If you want help then you have to make an effort to provide understandable information.
no changes in both
I asked you 4 questions and you reply with four words…
Yes. But can’t understand. I am only 12 years old
No
Same as posted above
I didn’t make any changes
