Sorry but I did not understand your instructions Do not go I think I have done other messes, to me the impression that I miss the comparison of the string
WidgetTerminal terminal(V1);
WidgetLED led1(V1);
WidgetLED led2(V1);
String content = "";
char character;
BLYNK_WRITE(V2)
int pinValue = param.asInt();
if (pinValue == HIGH) {
Blynk.virtualWrite(V0, "clr");
Blynk.virtualWrite(V1, LOW);
led1.off();
led2.off();
BLYNK_WRITE(V1)
// int pin = param.asInt();
// if (pin == HIGH) {
Blynk.virtualWrite(V1, 255);
led1.on();
//SwSerial.begin(115200);
//EspSerial.begin(115200);
timer.setInterval(10L, SerialInput); // Run every 100ms
Blynk.virtualWrite(V0, "clr"); // Clear the terminal from past info.
// timer.setInterval(500, Sent_serial);//Blynk.begin(auth, ssid, pass, IPAddress(192,168,1,100), 8080);
void SerialInput() {
if (Serial.available()) { // Guarda sulla seriali se ci sono dati in arrivo
character = Serial.read(); // Leggi il carattere seriale
content.concat(character); // Aggiungi carattere a stringere String
if (character == '\n') { // Carattere speciale che indica fine riga
Blynk.virtualWrite(V0, content); // invia una stringa al terminale
// content = ""; // Clear holding String
//Serial.print(content);
//________________
if (content == "Cucina")
led1.on();
else{
led1.off();
if (content == "Luci1")
Blynk.virtualWrite(V1,255);
led2.on();
else{
led2.off();
Serial.flush();//svuoto il buffer
In this instruction I can not get any print on the monitor so I figure out that the if statement does not occur
if (content == "Cucina")// this instruction
led1.on();
Sorry but for every led I have to use a different pinvirtual or I can always refer to the same pin.
Type of led1 pin v1 led2 pinv1 or Example led1 pin V1 led2 pinV2 and so on
woww… thats cool…
but i have any problem…
in scope i find new problem,
so what the problem in this scope… #define DEBUG_BSSL(fmt, …) DEBUG_ESP_PORT.printf_P((PGM_P)PSTR( “BSSL:” fmt), ## VA_ARGS)
C:\Users\andre\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.4\libraries\ESP8266WiFi\src\CertStoreBearSSL.cpp:56:5: note: in expansion of macro ‘DEBUG_BSSL’
DEBUG_BSSL(“CertStore::_preprocessCert: OOM\n”);
C:\Users\andre\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.4\libraries\ESP8266WiFi\src\CertStoreBearSSL.cpp: In static member function ‘static const br_x509_trust_anchor* BearSSL::CertStore::findHashedTA(void*, void*, size_t)’:
C:\Users\andre\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.4\libraries\ESP8266WiFi\src\CertStoreBearSSL.cpp:25:31: error: ‘DEBUG_ESP_PORT’ was not declared in this scope #define DEBUG_BSSL(fmt, …) DEBUG_ESP_PORT.printf_P((PGM_P)PSTR( “BSSL:” fmt), ## VA_ARGS)
C:\Users\andre\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.4\libraries\ESP8266WiFi\src\CertStoreBearSSL.cpp:208:9: note: in expansion of macro ‘DEBUG_BSSL’
DEBUG_BSSL(“CertStore::findHashedTA: OOM\n”);
exit status 1
Error compiling for board NodeMCU 1.0 (ESP-12E Module).
