I’m working on a project that requires a value to be taken from sensor connected with arduino, then sent the value to NodeMCU through Serial , then the same value again to the Blynk app. But I’m having problem as it didnt send the same value from arduino to Blynk. From arduino to NodeMCU, I managed to send the same value, but it seems that NodeMCU cannot sample the same received value to be resend to Blynk. Below is the code which I uploaded on NodeMCU, the code on Arduino is not uploaded since I think it’s not wrong. I felt like I’m missing something in the NodeMCU code. Please help me solve this issue.
char auth[] = "19db9b6385ca4c9e818e82f5576379be";
int myBPM;
char ssid[] = "Lolol";
char pass[] = "popopopo";
void myTimerEvent()
while (Serial.available() > 0) {
sensorBPM(); }
Blynk.notify("BPM is HIGH!");
while (!Serial) {
void sensorBPM()
myBPM = Serial.read();
Serial.println(myBPM);
Blynk.virtualWrite(V5,myBPM);
