Hi Blynkers
For my project I want to send value’s between my Esp8266 HUZZAH to my Nodemcu.
I was thinking to do this by sending the value to a Virtual Pin and than reading the one with the other module. Can I do this with bridge?
But is it even possible to share a Virtual pin between two modules?
Am I thinking in the right direction, am I missing something?
Thank you for reading!
Bridge is the way to do it, search the forum for Bridge examples.
Thank you very much for your reply!
I am now trying the example to blink an LED over bridge.
There is probably something wrong on the receiving code.
Any clues?
Sending code:
#include <Ethernet.h>
//NODEMCU
char auth[] = "KbNZdDoRZ2jFcc0Mm2o4GQSRbN_tUYe9";
// Bridge widget on virtual pin 1
WidgetBridge bridge1(V1);
// Timer for blynking
static bool value = true;
void blynkAnotherDevice() // Here we will send HIGH or LOW once per second
// Send value to another device
if (value) {
bridge1.digitalWrite(12, HIGH); // Digital Pin 12 on the second board will be set HIGH
bridge1.virtualWrite(V1, 1); // Sends 1 value to BLYNK_WRITE(V1) handler on receiving side.
// Keep in mind that when performing virtualWrite with Bridge,
// second board will need to process the incoming command.
// It can be done by using this handler on the second board:
// BLYNK_WRITE(V5){
// int pinData = param.asInt(); // pinData variable will store value that came via Bridge
bridge1.digitalWrite(12, LOW); // Digital Pin 9 on the second board will be set LOW
bridge1.virtualWrite(V1, 0); // Sends 0 value to BLYNK_WRITE(V5) handler on receiving side.
// Toggle value
value = !value;
BLYNK_CONNECTED() {
bridge1.setAuthToken("eB_UgC2p8R3I6NYH3QknkVMwr4Aawty4"); // Place the AuthToken of the second hardware here
Blynk.begin(auth);
// Call blynkAnotherDevice every second
timer.setInterval(1000L, blynkAnotherDevice);
Recieving code
//ESP8266 HUZZAH
char auth[] = "eB_UgC2p8R3I6NYH3QknkVMwr4Aawty4";
BLYNK_WRITE(V1){
// to avoid delay() function!
It doesn’t look like you are doing anything with the data in the ‘receiving’ code?
You receive the HIGH or LOW on V1 and D12, But there’s nothing in your code to do anything with this data?
For D12 you will need to define the pin as an output.
For V1 (param.asInt()), what are you proposing to do with that info? You receive it, but then nothing happens.
I’d suggest get your receiving device working as a standalone first, then incorporate control via bridge.
billd
Thank you @Bill_Donnelly!
I wrote this now:
But I’m still not very sure about it. I’m quite new to using bridge.
I wonder if I am placing everything in the right place (Outside of the void loop).
Also is the serial.print part right to read it on my computer?
The new code:
But I still don’t receive anything.
//ESP8266 HUZZAH
char auth[] = "**********************************************";
BLYNK_WRITE(V1){
Serial.println (param.asInt());
pinMode (12, OUTPUT);
Serial.begin(11500);
should only be in your setup()
You also don’t have any of the BLYNK connection commands in your setup()
, of the stuff for the wifi credentials. You need to add Blynk.begin(auth);
to the second device as well. They both need to be connected to BLYNK in order to talk to each other.
Also, make sure both devices are running, and connected. You can confirm they are connected by checking the device online status.
Additionally, confirm auth token in the bridg1.setAuthToken()
is correct.
//ESP8266 HUZZAH
/ Your WiFi credentials.
char pass[] = "YourPassword";
BLYNK_WRITE(V1){
Thank you very much for the reply.
I have removed pinMode (12, OUTPUT);
So now it is only in my setup.
I shall add the Blynk.begin(auth);
I guess this should also be added to my first device?
The set Auth should be correct .
Should I also put the bridge widget in the app?
Both devices need to be connected. It looks like you are using different connection methods for your two boards. Make sure you are using the proper commands for the connection method you are using.
It sounds like you should be using wifi connection for both. Therefore you need to make sure both sketches include the proper commands for a wifi connection.
Thank you so much! That did it
This is the working code for anyone who wants to have a basic code to try out bridge:
Sending code and the second one is the receiving code.
//NODEMCU
char auth[] = "****";
char ssid[] = "****";
char pass[] = "****";
// Wait until Blynk is connected
digitalWrite (12, HIGH);// write own led high
bridge1.digitalWrite(12, HIGH); // will trigger D12 HIGH on Device B. No code on Device B required
bridge1.virtualWrite(V1, "hello"); // you need to write code on Device B in order to receive this value.
BLYNK_CONNECTED() {
bridge1.setAuthToken("****"); // Token of the hardware B
//ESP8266 HUZZAH
BLYNK_WRITE(V1){
I would probably move that code out of the setup()
. Otherwise you will have to reset the board for it to run again.
Maybe something like you had originally:
//NODEMCU
bool value = true;
if (value) {
digitalWrite (12, HIGH); // Digital Pin 12 on the this board will be set HIGH
bridge1.virtualWrite(V1, "Hello"); // Sends "Hello" value to BLYNK_WRITE(V1) handler on receiving side.
else {
digitalWrite (12, LOW); // Digital Pin 12 on the this board will be set LOW
bridge1.virtualWrite(V1, "Hello Again"); // Sends "Hello Again" value to BLYNK_WRITE(V1) handler on receiving side.
// Toggle value
value = !value;
BLYNK_CONNECTED() {
Hey,
Thanks for the reply. At the moment I am a bit further with the code and made some improvements.
My setup is like this now:
Teensy sends a value of 1023 to the HUZZAH over serial.
Then the HUZZAH sends it to the NODEMCU over bridge.
Everything works fine apart from that the value I receive on the NODEMCU and HUZZAH is 225 instead of 1013.
My guess would be that the value is to big for serial write.
My goal is to eventually be able to send ldr sensor information from the Teensy to the NODEMCU. Thats why I chose the value 1023.
Any hints on how to get past that problem?
Teensy code:
// Setup computer to Arduino serial
// Setup Arduino to ESP8266 serial
// Use baud rate 115200 during firmware update
Serial1.begin(115200);
pinMode(20, INPUT);//LDR pin
int LDR = analogRead(A6);
//Serial1.write (LDR);
Serial1.write (1023);
//Serial.println (LDR);
delay (1000);
Serial1.write (0); // "50\r\n"
delay (1000);
HUZZAH code
//#define uint8 unsigned char
//HUZZAH
char auth[] = "";
char ssid[] = "";
char pass[] = "";
bool value = true;
int val = 0; //or uint8_t
if (value) {
//digitalWrite (12, HIGH); // Digital Pin 12 on the this board will be set HIGH
val = Serial.read();
Serial.println(val);
bridge1.virtualWrite(V1, val); // Sends recieved sensor value to BLYNK_WRITE(V1) handler on receiving side.
else {
//digitalWrite (12, LOW); // Digital Pin 12 on the this board will be set LOW
bridge1.digitalWrite(12, LOW); // Digital Pin 12 on the second board will be set LOW
// Toggle value
value = !value;
BLYNK_CONNECTED() {
bridge1.setAuthToken(""); // Token of the hardware B
NODEMCU CODE
//NODEMCU
char auth[] = "";
char ssid[] = "";
char pass[] = "";
BLYNK_WRITE(V1){
Serial.println (pinData);
At the receiving side you also need a blynk.virtualwrite at V1 for when V1 receives the data from the master. See blynk bridge example
