Sending email with Blynk
Is this example still working?
I tried it without any success… or only valid for legacy Blynk?
Is the only solution then trough notification?
[Notifications (Alerts) - Blynk Documentation ]
this is for Blynk 2.0. Should work, if it doesn’t, please provide examples of how to use the code.
You can create events. And sent email by trigger events
In Notification tab of event you can add you email
Thanks. Indeed through notification. It was much easier with legacy blynk!
How can I send a variable in the body of the email?
It seems I can only have “fixed” notification?
Just include the variable like “temp” in the example?
"Blynk.logEvent(“event_code”, String("High TemperatureDetected! Tº: ") + temp);"d?
Can the variable be a string? Size limited?
Correct
Value can be string type. Probably 300 symbols
Thanks!
