Sending Data from Arduino Mega to Blynk
Hello Community.
I hava a Problem.
I want to send the Data from a DHT22 to Blynk over a ESP8266-01.
The connection is working and the reading of the DHT22 too.
But when i open Blynk on my Android there are not the Data from the DHT22.
 *   Downloads, docs, tutorials: http://www.blynk.cc
 *   Sketch generator:           http://examples.blynk.cc
 *   Blynk community:            http://community.blynk.cc
 *   Social networks:            http://www.fb.com/blynkapp
 *                               http://twitter.com/blynk_app
 * This example shows how to use ESP8266 Shield (with AT commands)
 * to connect your project to Blynk.
 * WARNING!
 *   It's rather tricky to get it working, please read this article:
 *   https://github.com/blynkkk/blynk-library/wiki/ESP8266-with-AT-firmware
 * Change WiFi ssid, pass, and Blynk auth token to run :)
 * Feel free to apply it to any other example. It's simple!
#include <ESP8266_Lib.h>
#include <DHT.h>
#define DHT1PIN 53                                  //Pinbelegung DHT1
#define DHT1TYPE DHT22
// Instantiates and initializes the dht object
DHT dht1(DHT1PIN, DHT1TYPE);                        //Initialisieren DHT1
char auth[] = "XXXXXXXXXXXXX";
char ssid[] = "XXXXXXXXX";
char pass[] = "XXXXXXXX";
#define EspSerial Serial1
//#include <SoftwareSerial.h>
// Your ESP8266 baud rate:
#define ESP8266_BAUD 115200
ESP8266 wifi(&EspSerial);
void sendSensor()
  float h1 = dht1.readHumidity();
  float t1 = dht1.readTemperature(); // or dht.readTemperature(true) for Fahrenheit
  if (isnan(h1) || isnan(t1)) {
    return;
  Serial.println("Temperature: "+String(t1));
  Blynk.virtualWrite(V1, h1);
  Blynk.virtualWrite(V2, t1);
  // Set console baud rate
  // Set ESP8266 baud rate
  dht1.begin();
  timer.setInterval(10000L, sendSensor);
Here is the Serial Print.
[19]
___ __ __
/ _ )/ /_ _____ / /__
/ _ / / // / _ / '/
//_, /////_
__/ v0.4.6 on Arduino Mega
[604] Connecting to UPC246454487
[3639] AT version:1.3.0.0(Jul 14 2016 18:54:01)
SDK version:2.0.0(656edbf)
compile time:Jul 19 2016 18:44:44
OK
[4702] Failed to enable MUX
[9734] +CIFSR:STAIP,“192.168.192.3”
+CIFSR:STAMAC,“5c:cf:7f:a5:5e:80”
[9742] Connected to WiFi
[19902] Ready (ping: 11ms).
Temperature: 19.50
Temperature: 19.50
What is wrong? Do i have a problem in my Code?
Thank you.
not a 100% certain but I think the code after that 'return’will not run, so try removing it and see if it works.
Cheers
kev
Well, if your serial print is working, then so should your Blynk.virtualWrite() commands. What have you got in your app that is linked to V1 & V2 and what are the Reading Rates (PUSH or a time?)
Also, does your app show as connected to the device? If not, then that would explain… the device is connected to the server, thus running the script, but the app might not have the same auth code? Try resetting the auth in the app and replacing it in the sketch.
