@Danial Yes, that was the intention, wasn’t it?
Make the changes according to the suggestions above and give it a try.
@IBK Thanks for your fast replys.
'timer' was not declared in this scope
I can’t use the timer, is there a library i need to include so that it works
nedds to be added before you can use it …
@IBK Thanks for your fast reply.
Social networks: http://www.fb.com/blynkapp
http://twitter.com/blynk_app
This example shows how to use Arduino with HC-06/HC-05
Bluetooth 2.0 Serial Port Profile (SPP) module
to connect your project to Blynk.
Note: This only works on Android! iOS does not support SPP :(
You may need to pair the module with your smartphone
via Bluetooth settings. Default pairing password is 1234
NOTE: Bluetooth support is in beta!
#include <Stepper.h>
SoftwareSerial DebugSerial(0, 1); // RX, TX
byte forwards = 0;
byte backwards = 0;
// STEPPER MOTOR //////////////////////////////////////////
const int stepsPerRevolution = 200;
Stepper myStepper1(stepsPerRevolution, 47, 49, 51, 53); // 1 Stepper Motor
Stepper myStepper2(stepsPerRevolution, 2, 3, 4, 5); // 2 Stepper Motor
Stepper myStepper3(stepsPerRevolution, 39, 41, 43, 45); // 3 Stepper Motor
Stepper myStepper4(stepsPerRevolution, 10, 11, 12, 13); // 4 Stepper Motor
Stepper myStepper5(stepsPerRevolution, 6, 7, 8, 9); // 5 Stepper Motor
Stepper myStepper6(stepsPerRevolution, 23, 25, 27, 29); // 6 Stepper Motor
char auth[] = "-----------------------------------------------";
DebugSerial.begin(9600);
DebugSerial.println("Waiting for connections...");
// 9600 is for HC-06. For HC-05 default speed is 38400
Blynk.begin(Serial, auth);
timer.setInterval(50, driveMotors);
int sp = 300; //Motorspeed
myStepper1.setSpeed(sp); // setSpeed setzt die Maximale Geschwindigkeit der Schrittmotoren
myStepper2.setSpeed(sp); // "
myStepper3.setSpeed(sp); // "
myStepper4.setSpeed(sp); // "
myStepper5.setSpeed(sp); // "
myStepper6.setSpeed(sp); // "
void driveMotors()
if (forwards == 1) forward();
if (backwards == 1) backward();
void forward() {
myStepper1.step(-1);
myStepper2.step(-1);
myStepper3.step(-1);
myStepper4.step(-1);
myStepper5.step(1);
myStepper6.step(1);
void backward() {
myStepper1.step(1);
myStepper2.step(1);
myStepper3.step(1);
myStepper4.step(1);
myStepper5.step(-1);
myStepper6.step(-1);
void driveMotors()
BLYNK_WRITE(V0) {
int x = param[0].asInt();
int y = param[1].asInt();
if (y > 250) {
forwards = 1;
backwards = 0;
else if (y < 35) {
forwards = 0;
backwards = 1;
else {
forwards = 0;
backwards = 0;
When i run this code i get this error code message.
redefinition of 'void driveMotors()'
Not to much of a surprise if I look at the code:
@IBK
The Stepper motor doesn’t run…
byte forwards = 0;
byte backwards = 0;
char auth[] = "auth tokken is set correctly";
void forward() {
myStepper5.step(1);
myStepper6.step(1);
void backward() {
myStepper1.step(1);
myStepper2.step(1);
myStepper3.step(1);
myStepper4.step(1);
void driveMotors()
if (forwards == 1){
forward();
if (backwards == 1){
backward();
BLYNK_WRITE(V0) {
if (y > 250) {
forwards = 1;
backwards = 0;
else if (y < 35) {
forwards = 0;
backwards = 1;
else {
forwards = 0;
backwards = 0;
Here are my settings on my Blynk App:
Try this change …
Just did a quick test with one stepper motor. It work’s fine
// Nano conncted via Serial
// Joystick on V30
// Stepper motor on pin 2,3,4,5
byte forwards = 0;
byte backwards = 0;
Stepper myStepper1(10, 2, 3, 4, 5);
char auth[] = "xxx";
Serial.begin(38400);
timer.setInterval(10L, driveMotors);
void forward()
void backward()
myStepper1.step(1);
void driveMotors()
if(forwards == 1) forward();
if(backwards == 1) backward();
BLYNK_WRITE(V30)
if(y > 250)
forwards = 1;
backwards = 0;
else if(y < 35)
forwards = 0;
backwards = 1;
forwards = 0;
backwards = 0;
There may be an easier way to do this. I’m also using AccelStepper and a joystick. Rather than try to continuously send the step() command, I have the joystick set to the fastest write interval (100ms). On BLYNK_WRITE, I tell the motor to moveTo(motor.currentPosition() + 1000), where in my setup, 1000 steps takes just over 100ms to reach. That way, in between updates from the joystick’ BLYNK_WRITE call, the motor is in constant motion. When i release the joystick, Blynk sends a 0 to that call, and I tell the motor to stop().
Of course, I send a negative value if the joystick was slid down instead of up. You can use the value itself to scale the motor’s speed. In my case, I dont really care about the jog speed.
Point is, if you use moveTo() rather than step() you can keep the motor running smoothly.
Hope this helps!
Hi @IBK,
Thanks for your help, luckly it works now.
Do you know how i can implement the virtualslider for the motor speed ?
@Danial: A slider for speed control is possible,of course. But as you already have the joystick in use I’d suggest to base the speed control on that as well. Currently it only works as a kind of switch.
If you e.g. give the joystick y position a range from -10 to +10 you can:
- decide whether the motor shall “stop” ( y == 0 ), move direction “forwards” ( y > 0) or direction “backwards” ( y < 0)
- base the speed of the motor on the absolute value of y ( abs(y) ) by changing the timer interval value in ten steps.
@IBK Thanks for your fast reply. Is there any example for slider widgets, that would be really helpfull
@Danial: As I don’t do the programming for you I’d suggest you have a look at one of the examples from the Blynk library (Stroboscope.ino).
It shows how to adjust a timer using a slider - and this is what you need to do in your project as well.
Give it a try …
Hi @IBK I am coming back here again because i have no clue how to fix this problem with the slider and the speed.
I hope you can help me.
Best regards.
@Danial: There are several ways of changing the speed. At the end it’s changing the timer value depending on the slider position.
One possible solution could look like this (changes marked with “// ++)”:
// Joystick on V30
int timerID; // ++
byte forwards = 0;
byte backwards = 0;
BLYNK_CONNECTED() // ++
Blynk.syncAll(); // ++
BLYNK_WRITE(V20) // Slider, range 1..50, send on release // ++
int timerValue = param[0].asInt(); // ++
timerValue = constrain(timerValue, 1,50); // ++
timer.deleteTimer(timerID); // ++
timerID = timer.setInterval(timerValue, driveMotors); // ++
BLYNK_WRITE(V30)
if(y > 250)
forwards = 1;
backwards = 0;
else if(y < 35)
forwards = 0;
backwards = 1;
forwards = 0;
backwards = 0;
timerID = timer.setInterval(10L, driveMotors); // ++
void forward()
void backward()
myStepper1.step(1);
void driveMotors()
