BLYNK
BLYNK.IO       📲 GETTING STARTED       đź“— DOCS       👉 SKETCH BUILDER
Selector switch
Have a nice day
I need to control old fan it has selector switch , When one switch is pressed (ON) another switch released ( OFF)
I need four selector switch
Can Blynk app has such switch
Please advice
You could use a Segmented Switch widget, or you could make your own using four Button or Styled Button widgets and handle the logic with some simple code.
Dear Pete Thanks for the reply
I think Segmented Switch maybe suitable
Dayan
Yes… My first step is succeed by the help of Pete
Now I need to turn OFF the Fan withing 30 minutes and turn ON again 30 minutes and so on
How should I combine Segmented switch and timer
Please advice
Search this forum for “Timeout Timer” and you’ll see some examples.
I tried but could not find the such information
long variableTime = 1000; // default interval time of 1 second
int varTimer;  // Setup Timeout Timer ID
BLYNK_WRITE(V0) { // Widget for interval timing
  variableTime = param.asInt();
  if (variableTime <= 0) { // prevents a timer from becoming 0 or less
    variableTime = 1;
  timerLoop();  // Call your timed loop
void timerLoop() {
  timer.deleteTimer(varTimer);  // Cancel previous Timeout Timer
  //  Do your stuff here every (variableTime) seconds
  varTimer = timer.setTimeout(variableTime, timerLoop);  // Set new Timeout timer
By @Gunner
