Gunner
January 27, 2020, 8:14am
21
PeteKnight:
but the boss man saysâŚ
Yep, da boss man has said a lot of things
Honestly, I donât care and shouldnât have gotten involved in this topic as I never liked Blynkâs BT/BLE (it was not reliable enough for me) and I actually donât actively use Blynk anymore either. Came for the Python interest, got stuck in the debating again⌠my bad
I agree, I really hope that Bluetooth/BLE doesnât make it into Blynk 2.0 when it eventually makes an appearance.
khoih
January 27, 2020, 5:29pm
23
Update
Just tested and verified the double-dipping WiFi and BT/BLE can work simultaneously using the above sketch / lib mod. All the previously-working widgets are still working correctly.
The terminal output
Use WiFi to connect Blynk
[251] Connecting to HueNet1
[2412] Connected to WiFi
[2412] IP: 192.168.2.109
[2412]
___ __ __
/ _ )/ /_ _____ / /__
/ _ / / // / _ \/ '_/
/____/_/\_, /_//_/_/\_\
/___/ v0.6.1 on ESP32
[2418] BlynkArduinoClient.connect: Connecting to acount.duckdns.org:8080
[2524] Ready (ping: 6ms).
Use BT to connect Blynk
[2594]
___ __ __
cpm = 0 - RadiationValue = 0.00uSv/h - Equivalent RadiationDose = 0.0000uSv
[25805] BT connect
[25831] Ready (ping: 25ms).
Mine has worked with one Project! I just selected Bluetooth as connection Type and WiFi worked well:)
khoih
January 30, 2020, 3:18pm
25
Thatâs a much better way to do as Iâm really not an experienced user of BT/BLE.
Update Feb 5th 2020
Hello @Crosswalkersam ,
FYI, just update the BlynkESP32_BT_WF lib to v1.0.2 to provide similar WiFiManagerâs Config Portal support.
Update Feb 5th 2020
New in Version 1.0.2
This new version enables user to eliminate hardcoding your Wifi and Blynk credentials, thanks to the Smart Config Portal, and have Credentials ( WiFi SID/PW, Blynk WiFi/BT/BLE Tokens/ Hardware Port ) saved in either SPIFFS or EEPROM.
Provide similar features as Blynk_WM
[Selection_1]
[ConfigPortal]
Update Feb 25th 2020
Releases v1.0.3
Add checksum for config data integrity.
Add clearConfigData() to enable forcing into ConfigPortal Mode when neceâŚ
