Simple question. Is there a way I can set/change what OPTION is active in a Segmented Switch from the hardware side and see that reflected on the App. I tried : (in the case where Segmented Switch is V1 and I want to select OPTION 2
Yes, the same way as a button, slider, etc… just as you show above, using a Blynk.virtualWrite(vPin, value) command, works for me on Android.
You will have to follow that up with a Blynk.syncVirtual(vPin) to "process " the command as if it was pressed on the App in order to trigger whatever Blynk function it controls. Again same as sketch controlled buttons, sliders and so on.
Because with this code where V0 is a 5 segmented switch and the sketch start with a
int inputSelected = 1;
if I click on the V50 widget (a simpe button) with this code
BLYNK_WRITE(V50) {
if (param.asInt() == 1) {
if (inputSelected == 1) { Blynk.virtualWrite(V0, 1); Blynk.syncVirtual(V0);}
if (inputSelected == 2) { Blynk.virtualWrite(V0, 2); Blynk.syncVirtual(V0);}
if (inputSelected == 3) { Blynk.virtualWrite(V0, 3); Blynk.syncVirtual(V0);}
if (inputSelected == 4) { Blynk.virtualWrite(V0, 4); Blynk.syncVirtual(V0);}
if (inputSelected == 9) { Blynk.virtualWrite(V0, 5); Blynk.syncVirtual(V0);}
or like this:
BLYNK_WRITE(V50) {
if (inputSelected == 1) { Blynk.virtualWrite(V0, 1); }
if (inputSelected == 2) { Blynk.virtualWrite(V0, 2); }
if (inputSelected == 3) { Blynk.virtualWrite(V0, 3); }
if (inputSelected == 4) { Blynk.virtualWrite(V0, 4); }
if (inputSelected == 9) { Blynk.virtualWrite(V0, 5); }
the input ID 1 of the segmented switch is select correctly, but don’t trigger the command in the “case 1” of segmented switch. If I press manually on the app on ID 1, then trigger all ok.
