Please post your full serial monitor output from device boot-up.
@PeteKnight thank you for your quick reply. here is the serial monitor output
15:17:38.094 -> [WiFiEsp] Initializing ESP module
15:17:39.102 -> [WiFiEsp] >>> TIMEOUT >>>
15:17:44.046 -> [WiFiEsp] >>> TIMEOUT >>>
15:17:44.046 -> [WiFiEsp] End tag not found
15:17:44.046 -> [WiFiEsp] Warning: Unsupported firmware
15:17:48.063 -> Connecting to GoCO
15:17:53.782 -> [WiFiEsp] Connected to GoCO
15:17:53.782 -> You're connected to the network
15:17:53.782 -> [15685]
15:17:53.782 -> ___ __ __
15:17:53.782 -> / _ )/ /_ _____ / /__
15:17:53.782 -> / _ / / // / _ \/ '_/
15:17:53.782 -> /____/_/\_, /_//_/_/\_\
15:17:53.782 -> /___/ v1.0.1 on Arduino Uno
15:17:53.829 ->
15:17:54.298 -> [16198] Connecting to GoCO
15:18:07.348 -> [29230] AT version:1.6.2.0(Apr 13 2018 11:10:59)
15:18:07.348 -> SDK version:2.2.1(6ab97
15:18:13.382 -> [35286] +CIFSR:STAIP,"192.168.1.201"
+CIFSR:STAMAC,"24:a1:60:3d:86:6b"
15:18:13.382 ->
15:18:13.382 -> [35287] Connected to WiFi
15:18:23.678 -> [45596] Ready (ping: 13ms).
15:18:59.194 -> [81078] Ready (ping: 18ms).
15:19:34.510 -> [116410] Ready (ping: 28ms).
Youâre using SoftwareSerial on an Uno and attempting to use a baud rate of 115200, yet SoftwareSerial for AVR devices doesnât work successfully at rates higher than 9600.
I have no idea what the WiFiEsp library does, but itâs throwing some error messages that youâre ignoring.
Exactly what hardware are you using?
@PeteKnight I am currently using an UNO board, ESP-01s(ESP8266)(wifi board) and a AM2302(DHT22) (temperature sensor) and a DC light bulb. The baud rate is set to be 115200 due to the ESP8266. Its need to be run under 115200. I tried to change it back to 9600 but the esp module cannot not be initialize and cannot even connect to wifi.
You need to set your ESP-01 to work at 9600 via an AT command, otherwise this hardware setup wonât work.
If you donât have the necessary hardware or skills to do this then you could switch to a Mega and use a physical UART, but TBH youâd be better off dumping the whole Arduino mess and going for a NodeMCU or ESP32 with built-in WiFi connectivity.
@PeteKnight thx for your advice, I think I have changed the baud rate of ESP to 9600 now.
the serial monitor become
17:23:15.810 -> [WiFiEsp] Initializing ESP module
17:23:19.507 -> [WiFiEsp] Initilization successful - 2.2.1
17:23:19.554 -> Connecting to GoCO
17:23:25.319 -> [WiFiEsp] Connected to GoCO
17:23:25.319 -> You're connected to the network
17:23:25.366 -> [9513]
17:23:25.412 -> ___ __ __
17:23:25.412 -> / _ )/ /_ _____ / /__
17:23:25.412 -> / _ / / // / _ \/ '_/
17:23:25.459 -> /____/_/\_, /_//_/_/\_\
17:23:25.506 -> /___/ v1.0.1 on Arduino Uno
17:23:25.506 ->
17:23:25.976 -> [10169] Connecting to GoCO
17:23:29.197 -> [13352] AT version:1.6.2.0(Apr 13 2018 11:10:59)
17:23:29.197 -> SDK version:2.2.1(6ab97e9)
17:23:29.244 -> compile time:Sep 10 2019 17:31:08
17:23:29.244 -> OK
17:23:34.621 -> [18800] +CIFSR:STAIP,"192.168.1.201"
17:23:34.667 -> +CIFSR:STAMAC,"24:a1:60:3d:86:6b"
17:23:34.667 -> [18809] Connected to WiFi
17:23:45.393 -> [29575] Ready (ping: 43ms).
17:24:20.971 -> [65149] Ready (ping: 45ms).
17:24:56.547 -> [100723] Ready (ping: 46ms).
and my code changed to
#define BLYNK_TEMPLATE_ID "TMPL5vzGTnYc"
#define BLYNK_DEVICE_NAME "DHT22"
#define BLYNK_AUTH_TOKEN "";
//Libraries
#include <DHT.h>;
#include <ESP8266_Lib.h>
//#include <ESP8266WiFi.h>;
#include "WiFiEsp.h"
#ifndef HAVE_HWSERIAL1
#include "SoftwareSerial.h"
SoftwareSerial Serial1(6, 7); // RX, TX
#endif
#define DHTPIN 10 // connect the dht output to 10(pwm)
#define DHTTYPE DHT22 // DHT 22 (AM2302)
#define led 8 //connect to led to pin 8-->change to motor later
DHT dht(DHTPIN, DHTTYPE); //// Initialize DHT sensor for normal 16mhz Arduino
//#include <SimpleTimer.h>
#define EspSerial Serial1
#define ESP8266_BAUD 9600
//Variables
int chk;
float hum; //Stores humidity value
float temp; //Stores temperature value
char ssid[] = "GoCO"; //You can replace the wifi name to your wifi
char pass[] = ""; //Type password of your wifi.
int status = WL_IDLE_STATUS; // the Wifi radio's status
char auth[] = "";
ESP8266 wifi(&EspSerial);
//int virtual_pin_value = param.asInt();
//param.asStrng()
//param.asFloat()
//BlynkTimer timer;
void delaytimer()
int count = 0;
Serial.print("delay");
Serial.print(count);
count++;
// initialize serial for debugging
// initialize serial for ESP module
Serial1.begin(9600);
// initialize ESP module
WiFi.init(&Serial1);
pinMode(LED_BUILTIN, OUTPUT);
dht.begin(); //start running the dht
pinMode (led, OUTPUT); //set the led(pin8) as output
pinMode (LED_BUILTIN, OUTPUT); //set the led on board as output
WifiStatus();
void WifiStatus()
// check for the presence of the shield
if (WiFi.status() == WL_NO_SHIELD) {
digitalWrite(LED_BUILTIN, LOW); //no on board led if no wifi
Serial.println("WiFi is not connected");
// don't continue
while (true);
// attempt to connect to WiFi network
while ( status != WL_CONNECTED) {
digitalWrite(LED_BUILTIN, HIGH);//connecting have on board led
Serial.println(ssid);
// Connect to WPA/WPA2 network
status = WiFi.begin(ssid, pass);
// you're connected now, so print out the data
Serial.println("You're connected to the network");
timer.setTimeout(3600000L, [] () {} ); // dummy/sacrificial Function
timer.setInterval(5000L, sensorDataSend); // call the take_sensor_reading() function every 5 seconds
sensorDataSend();
void sensorDataSend()
//timer.setInterval(200L, delaytimer);
timer.setTimeout(20, delaytimer);
hum = dht.readHumidity();
temp = dht.readTemperature();
//Print temp and humidity values to serial monitor(help checking the data)
Serial.print("Humidity: ");
Serial.print(hum);
Serial.print(" %, Temp: ");
Serial.print(temp);
Serial.println(" Celsius");
if (temp >= 20) //running the motor with sensor
digitalWrite(led, HIGH); //switch on motor
digitalWrite(led, LOW); //switch off motor
// sensorValue = analogRead(A5); // reading sensor from analog pin
// Blynk.virtualWrite(V1, sensorValue); // sending sensor value to Blynk app
BLYNK_WRITE(V1) // Executes when the value of virtual pin 1 changes
if (param.asInt() == 1)
// execute this code if the switch widget is now ON
sensorDataSend();
// execute this code if the switch widget is now OFF
Okay, now Iâd recommend that you dump all of the WiFiEsp code and delete void WifiStatus() and put this in your void setupâŚ
Also, you donât need thisâŚ
because youâre not referencing the timers by their IDs.
and, as I said before, Iâd dump all of the delaytimer rubbish.
@PeteKnight
Am I doing it right?? For the wifiesp code, if I deleted them will it affect the running of esp8266?
The serial moniter become
18:14:59.529 -> [WiFiEsp] Initializing ESP module
18:15:03.233 -> [WiFiEsp] Initilization successful - 2.2.1
18:15:03.233 -> [3699]
18:15:03.233 -> ___ __ __
18:15:03.279 -> / _ )/ /_ _____ / /__
18:15:03.326 -> / _ / / // / _ \/ '_/
18:15:03.326 -> /____/_/\_, /_//_/_/\_\
18:15:03.326 -> /___/ v1.0.1 on Arduino Uno
18:15:03.373 ->
18:15:03.842 -> [4336] Connecting to GoCO
18:15:07.016 -> [7520] AT version:1.6.2.0(Apr 13 2018 11:10:59)
18:15:07.063 -> SDK version:2.2.1(6ab97e9)
18:15:07.109 -> compile time:Sep 10 2019 17:31:08
18:15:07.109 -> OK
18:15:12.497 -> [12964] +CIFSR:STAIP,"192.168.1.201"
18:15:12.497 -> +CIFSR:STAMAC,"24:a1:60:3d:86:6b"
18:15:12.544 -> [12974] Connected to WiFi
18:15:23.081 -> [23568] Ready (ping: 45ms).
18:15:58.647 -> [59138] Ready (ping: 46ms).
and the code is
//Libraries
#include <DHT.h>;
#endif
//Variables
int chk;
char auth[] = "";
//param.asStrng()
//param.asFloat()
//BlynkTimer timer;
void delaytimer()
int count = 0;
count++;
//timer.setTimeout(3600000L, [] () {} ); // dummy/sacrificial Function
sensorDataSend();
//WifiStatus();
/*void WifiStatus()
// don't continue
while (true);
Serial.print(hum);
Serial.print(temp);
sensorDataSend();
Whatâs the purpose of the blinking builtin led besides some cool blinking? Itâs on a device barely looked at and it will keep blinking (5 seconds not!) even if your sensorreading is not working okâŚ
I would skip that code also and focus on a deadband function for switching your motor on/off. If temp constantly variates between 19.9 and 20.1 your motor will keep switching on and off and will kill it.
@bazzio I think I have deleted that part for blinking the built in led. Also, the previous code is work until I connected to the Blynk server. The temperature is quite constant when I only run it with the motor.
Yes, it should make it work correctly.
This commandâŚ.
emphasized text[quote=âNeptune, post:28, topic:56463â]
[/quote]
will connect to the WiFi then to the Blynk server. Anything you do with setting-up a WiFi connection before that will get in the way.
It would make much more sense for you to start with the Blynk example sketch, and change the ESP baud rate to 9600âŚ.
You are using simple timer and yet you have commented out the simple timer library?? Surely you would get an compile error?
@PeteKnight I am so sorry. could you specify which library I should delete? I am not sure about that. I am really sorry.
Have you looked at the example sketch I linked to?
@PeteKnight yup, when I try to compile the code. this line got error
it said
Arduino: 1.8.15 (Windows 10), Board: "Arduino Uno"
dht22_test:23:15: error: 'EspSerial' was not declared in this scope
C:\Users\user\Desktop\dht22_test\dht22_test.ino:23:15: note: suggested alternative: 'Serial'
Serial
C:\Users\user\Desktop\dht22_test\dht22_test.ino: In function 'void setup()':
dht22_test:74:3: error: 'EspSerial' was not declared in this scope
C:\Users\user\Desktop\dht22_test\dht22_test.ino:74:3: note: suggested alternative: 'Serial'
Serial
exit status 1
@PeteKnight I have redesigned the code now, is this better?
// generated by mBlock5 for <your product>
// codes make you happy
//#include "src/OfflineBroadcast.h"
//#include "DHT_sensor_library-1.4.1/DHT.h"
//#include "Adafruit_Sensor-master/Adafruit_Sensor.h"
#define BLYNK_AUTH_TOKEN "nfxC29MO9ja1n6hzopoqMg2EA56Znw6N";
#include <DHT.h>
#include <Arduino.h>
#include <Wire.h>
DHT dht(10, DHT22);
float WIFI_ON_OFF = 0;
float Fan_On_Off = 0;
SoftwareSerial EspSerial(6, 7);
char pass[] = "29882992";
char auth[] = " nfxC29MO9ja1n6hzopoqMg2EA56Znw6N";
//OfflineBroadcast broadcaster;
void Fan_on() {
digitalWrite(8, 1);
//broadcaster.callOK();
void Fan_off() {
digitalWrite(8, 0);
void No_wifi() {
while (1) {
if ((dht.readTemperature() > 20) || (dht.readTemperature() == 20.000000)) {
Fan_on();
Fan_off();
// _loop();
BLYNK_WRITE(V6) {
Fan_On_Off = param.asDouble();
void Wifi_On() {
while (1) {
if (Fan_On_Off == 1.000000) {
Fan_on();
Fan_off();
// _loop();
void _delay(float seconds) {
long endTime = millis() + seconds * 1000;
while (millis() < endTime) _loop();
//delay(10);
pinMode(8, OUTPUT);
dht.begin();
WIFI_ON_OFF = 0;
Fan_On_Off = 0;
WIFI_ON_OFF = 1;
while (1) {
if (WIFI_ON_OFF == 1.000000) {
Wifi_On();
No_wifi();
//_loop();
broadcaster.on(String("On"),broadcastHandler);
broadcaster.on(String("Off"),broadcastHandler1);
broadcaster.on(String("Wifi Off"),broadcastHandler2);
broadcaster.on(String("Wifi On"),broadcastHandler3);
void _loop() {
//broadcaster.loop();
However it show this time
12:38:08.695 -> ___ __ __
12:38:08.695 -> / _ )/ /_ _____ / /__
12:38:08.740 -> / _ / / // / _ \/ '_/
12:38:08.786 -> /____/_/\_, /_//_/_/\_\
12:38:08.786 -> /___/ v1.0.1 on Arduino Uno
12:38:08.831 ->
12:38:09.297 -> [587] Connecting to GoCO
12:38:10.322 -> [1602] ESP is not responding
Try this :
WARNING!
It's very tricky to get it working. Please read this article:
http://help.blynk.cc/hardware-and-libraries/arduino/esp8266-with-at-firmware
This example shows how value can be pushed from Arduino to
the Blynk App.
WARNING :
For this example you'll need Adafruit DHT sensor libraries:
https://github.com/adafruit/Adafruit_Sensor
https://github.com/adafruit/DHT-sensor-library
App project setup:
Value Display widget attached to V5
Value Display widget attached to V6
#define BLYNK_TEMPLATE_ID "TMPLxxxxxx"
#define BLYNK_DEVICE_NAME "Device"
#define BLYNK_AUTH_TOKEN "YourAuthToken"
#include <DHT.h>
char pass[] = "YourPassword";
//#define EspSerial Serial1
// Your ESP8266 baud rate:
#define ESP8266_BAUD 38400
#define DHTPIN 2 // What digital pin we're connected to
//#define DHTTYPE DHT22 // DHT 22, AM2302, AM2321
//#define DHTTYPE DHT21 // DHT 21, AM2301
void sendSensor()
float h = dht.readHumidity();
if (isnan(h) || isnan(t)) {
return;
Blynk.virtualWrite(V5, h);
Blynk.virtualWrite(V6, t);
// Set ESP8266 baud rate
//Blynk.begin(auth, wifi, ssid, pass, "blynk.cloud", 80);
//Blynk.begin(auth, wifi, ssid, pass, IPAddress(192,168,1,100), 8080);
dht.begin();
Iâm assuming that you didnât comment-out the Mega section an un-comment the Uno section.
He did but heâs not using the right pins, he should use (2, 3) instead of (6, 7)
