Saving data with Blynk
Hi, I want to know if it is possible to use blynk to save data or send data to my website. If yes, can you help me how? Thank you :slight_smile:
All data you send from Hardware to Blynk is saved by default. But you can access it only via application (we don’t have any other interface at the moment). If you need more than that - you have to install local Blynk server and you’ll be able to get all your in csv files.
Thank you for your response, what do you mean “data you send from Hardware to Blynk is saved by default.”?
in using local server, how can i get a csv files?
thank you so much :blush:
Here is some info.
