Same project for various mobile devices
I have an application where more than one mobile device (Android and/or iOS) need to access the same hardware (ESP8266). However, due to the token, this not being possible. Has anyone done this?
-x-x-x-x-x-x-x-x -x code-x-x-x-x-x-
#include <Ethernet.h>
AUTH char [] = “this_is_my_problem”;
// Set password to “” for open networks.
ssid char [] = “network”;
char pass [] = “password”;
WidgetLED LED1 (V1);
void setup ()
Serial.begin (9600);
Blynk.begin (auth, ssid, pass);
// Make pin D2 default HIGH, and attach INT to our handler
pinMode (D4 INPUT_PULLUP);
checkPin void ()
if (digitalRead (D4) == LOW) {
led1.off ();
} Else {
led1.on ();
void loop ()
Blynk.run ();
checkPin ();
you can share access to your Blynk project or even share the project itself
http://docs.blynk.cc/#sharing
It is true!
I set “Share your Project configuration” . I will try to “Share access to your hardware”.
Thank you very much!
@hernani.galindo you can also use same account on different devices.
