RTC with Arduino NANO+HM10 Bluetooth
Hi there,
My RTC only shows the time from the Start starting at 0:0:0 1.1.1970.
Where is the RTC Widget pulling the Time Information when using Blynk over Bluetooth(wich works fine btw)?
Code:
SoftwareSerial mySerial(10, 11); // RX, TX
#include <TimeLib.h>
#include <WidgetRTC.h>
char auth[] = "";
WidgetRTC rtc;
BLYNK_ATTACH_WIDGET(rtc, V5);
// Digital clock display of the time
void clockDisplay()
  // You can call hour(), minute(), ... at any time
  // Please see Time library examples for details
  Serial.print(currentTime);
  Serial.print(" ");
  Serial.print(currentDate);
  Serial.println();
  // Send time to the App
  Blynk.virtualWrite(V1, currentTime);
  // Send date to the App
  Blynk.virtualWrite(V2, currentDate);
 rtc.begin();
  mySerial.begin(9600);
  Blynk.begin(mySerial, auth);
  timer.setInterval(10000L, clockDisplay);
Sorry, RTC doesn’t work over Bluetooth right now.
