RTC not pulling time from server
[0] Using static IP
[1300] IP:192.168.1.50
[1300]
___ __ __
/ _ )/ /_ _____ / /__
/ _ / / // / _ / '/
//_, /////_
__/ v0.4.3 on Arduino Nano
[1412] Free RAM: 1168
[5001] Connecting to blynk-cloud.com:8442
[5117] <[02|00|01|00]
[5117] <27851b7651394c86b4e4aa4066ec7341
[5170] >[00|00|01|00|C8]
[5170] Ready (ping: 50ms).
[5176] <[11|00|01|00]e
[5200] <ver[00]0.4.3[00]h-beat[00]10[00]buff-in[00]256[00]dev[00]Arduino Nano[00]cpu[00]ATmega328P[00]con[00]W5100[00]build[00]Jan 17 2017 14:02:47[00]
[5360] <[10|00|02|00|06]
[5387] <vr[00]255
[5406] >[00|00|01|00|C8]
[5450] >[00|00|02|00|02]
Current time: 0:0:15 1 1 1970
[15406] <[14|00|03|00|0B]
[15407] <vw[00]1[00]0:0:15
[15428] <[14|00|04|00|0D]
[15456] <vw[00]2[00]1 1 1970
[15488] <[06|00|05|00|00]
[15561] >[00|00|05|00|C8]
Current time: 0:0:25 1 1 1970
    Social networks:            http://www.fb.com/blynkapp
                                http://twitter.com/blynk_app
  Blynk can provide your device with time data, like an RTC.
  Please note that the accuracy of this method is up to several seconds.
  App project setup:
    RTC widget (no pin required)
    Value Display M widget on V1
    Value Display M widget on V2
  WARNING :
  For this example you'll need SimpleTimer library:
    https://github.com/jfturcot/SimpleTimer
  And also this Time keeping library:
    https://github.com/PaulStoffregen/Time
  This code is based on an example from the Time library:
    https://github.com/PaulStoffregen/Time/blob/master/examples/TimeSerial/TimeSerial.ino
#define BLYNK_DEBUG
#include <Ethernet.h>
#include <TimeLib.h>
#include <WidgetRTC.h>
char auth[] = "27851b7651394c86b4e4aa4066ec7341";
IPAddress device_ip  (192, 168,   1,  50);
IPAddress dns_ip     (  8,   8,   8,   8);
IPAddress gateway_ip (192, 168,   1,   1);
IPAddress subnet_mask(255, 255, 255,   0);
WidgetRTC rtc;
// Digital clock display of the time
void clockDisplay()
  // You can call hour(), minute(), ... at any time
  // Please see Time library examples for details
  String currentDate = String(month()) + " " + day() + " " + year();
  Serial.print(currentTime);
  Serial.print(" ");
  Serial.print(currentDate);
  Serial.println();
  // Send time to the App
  Blynk.virtualWrite(V1, currentTime);
  // Send date to the App
  Blynk.virtualWrite(V2, currentDate);
  Blynk.begin(auth, "blynk-cloud.com", 8442, device_ip, dns_ip, gateway_ip, subnet_mask);
  // Begin synchronizing time
  rtc.begin();
  // Other Time library functions can be used, like:
  //   timeStatus(), setSyncInterval(interval)...
  // Read more: http://www.pjrc.com/teensy/td_libs_Time.html
  // Display digital clock every 10 seconds
  timer.setInterval(10000L, clockDisplay);
The same here.
Not getting time from Server
Using local server v .21.7
I updated to latest library and now nothing compiles
RTC widget required some time to kick start. So to solve this problem you can use conditions which will check does the time &date. update or not.
For example .
If(year!=1970)
//Do you rtc tasks
You need 0.4.4 for that code.
That fixed it,
thank you
Hi. The same problem with local and cloud server. Library 0.4.4…No sync.
@Arsen I did what I thought would be a quick test yesterday. Like a numpty I was forgetting to add the RTC widget.
If you have included the widget and have the correct versions of “everything” have you looked into setSyncInterval?
Various posts on this site covering setSyncInterval.
Of course widget was added, and I
tried setsync, no result. The older scetch version with pin widget RTC working good.
@Arsen which app version?
2 7 1. Version app doesn’t matter, in com port monitor wrong data.
Blynk v0.3.7 at the picture… Not v0.4.4…??
yep…Thanx!
Well spotted @psoro and @Arsen app version does matter.
If the Serial Monitor you provide for us shows a library that doesn’t work with the new RTC widget then I would assume you haven’t installed the correct libraries.
If you are still having problems sketch and Serial Monitor (showing correct library) please.
