Routine for blynk controlled relay
I have a NodeMCU esp-12e that is setup to control a relay, I would like to setup a routine that would automatically trigger a second time at a set interval after triggered by Blynk app
As always, rules are easy:
  1. Make it work without Blynk
  2. Add Blynk on top
What have you already accomplished?
Here is the program code
"#define BLYNK_PRINT Serial
"#include ESP8266WiFi.h> "
#include BlynkSimpleEsp8266.h>”
char auth[] = “******************”;
Blynk.begin(auth, “", "*****”);
had to put " " around the first 3 lines and remove < for it to be visible
programing this on the NodeMCU ESP-12E with Arduino IDE
