Room thermostat: how compare two variables
Dear all, sorry for the banality of my question.
I simply would like to realize a “room thermostat” that is able to close a contact when the temperature is lower than the one I set up.
To do this I used a “step widget” to set up the temperature desired (set_temp) and use a function to take over the ambient temp that is sent every 1 sec to WeMos.
The question is: how can I compare the set_temp with real ambient temp in order to set at level HIGH a PIN?? It seems that “set_temp” is a local variable inside BLYNK_WRITE(V1) and I’m not able to compare this with other variables.
I tried to use IF in void loop() but “set_temp” is not recognized.
Sorry for this very banal question, but can someone help me?
Thanks!!
#include <WidgetRTC.h>
char auth[] = "0626d4c5d0314XXXXXXXXXXXXXXXX0";
char ssid[] = "XXXXXXX";
char pass[] = "XXXXXXXX";
#define pin_temp A0
#define pinout_d6 D6
WidgetRTC rtc;
  pinMode(pin_temp, INPUT);
  pinMode(pinout_d6, OUTPUT);
  rtc.begin();
  timer.setInterval(1000L, inviaMisura);
  timer.setInterval(10000L, clockDisplay);
// recupera tutti i valori dal server nel caso in cui WeMas si spenga o resetti
BLYNK_CONNECTED() {
Blynk.syncAll();
BLYNK_WRITE(V1) // Step Widget writes to Virtual Pin V1 to set the temp you want
  float set_temp = param.asFloat();
  Blynk.virtualWrite(2, set_temp);
// Digital clock display of the time
void clockDisplay()
  // You can call hour(), minute(), ... at any time
  // Please see Time library examples for details
  String currentTime = String(hour()) + ":" + minute(); // + ":" + second();
  String currentDate = String(day()) + " " + month(); // + " " + year();
  Blynk.virtualWrite(V50, currentTime);
  Blynk.virtualWrite(V51, currentDate);
void inviaMisura()
 /*misuro la temperatura in ingresso =================*/
  float t = 0.00;
  for (byte i = 0; i < 5; i++) { //Esegue l'istruzione successiva 5 volte
      t += (analogRead(pin_temp));
  t /= 5; //Calcola la media dei  valori di temperatura
  //Serial.println(t);
  float t_reale = t * ((3.3/1023)*100);
  Blynk.virtualWrite(3, t_reale);              // invia al pin virtuale Blynk 3 il valore della temperatura
  timer.run(); // esegue timer
  if(t_reale < set_temp) {
  digitalWrite(pinout_d6, HIGH);
  else {
  digitalWrite(pinout_d6, LOW);
You are setting this as a local variable, define it as a global.
Also keep loop() to just 2 lines of code like PUSH_DATA example until you gain experience with Blynk.
Thanks Costas, I got it. Now it’s ok
char auth[] = "XXXXXXXXXXXXXXXXXXX";
char ssid[] = "XXXXXX";
#define pin_temp A0
float set_temp;
float t_reale;
WidgetRTC rtc;
  rtc.begin();
BLYNK_CONNECTED() {
Blynk.syncAll();
void clockDisplay()
void inviaMisura()
  float t = 0.00;
  else {
