RGB Led strip with Raspberry pi 2 virtual pwm support
Hey,
i have a 12V RGB Led strip and wan’t to control all colors… But the Raspberry pi has only one pwm gpio (18)… How can I connect every color with virtual pwm?
Thank you!:slight_smile:
The question is way too generic… Could you be more specific?
What do you mean virtual PWM? I suppose you mean Software PWM… in this case you’ll have to connect an appropriate library for such things.
Yeah, I mean Software PWM :smile: do you know a good Python library?:slight_smile:
@vshymanskyy can you help me please?:slight_smile:
  1. Try using our JS library. it’s MUCH easier to use on Raspberry Pi…
    http://www.instructables.com/id/Blynk-JavaScript-in-20-minutes-Raspberry-Pi-Edison/
  2. You can use pi-blaster frome node.js to get as many PWM channels as you like
hope that helps…
