For starters I’m new here
I’ve selected 8 datastreams for my report widget. Totally i have 5 value widgets, 1 terminal widget, 1 LCD widget and 3 LED widgets. However, the report generated only displays the LED widget brightness. Nothing else is included in the csv file.
I’d like to mention that the value widgets are virtual pin values.
I’m running the arduino IDE with a Sparkfun ESP8266 thing dev.
Blynk library version 0.5.4 i think.
Would like to mention everything works fine with the values displayed correctly in all widgets on the app except that the report widget doesn’t generate the same information in the app.
Also, I’m using the cloud server for now…but i think i’ll switch to local server soon.
Please help.
(I have a hunch…
In the code i’ve used string format to link the data to the virtual pin. I wonder if that’s the reason. Should i directly use float instead?)
