Hi friends. is it possible to remove [" β] symbol from webhook get ? I just need the pin value in webhook get without [β "].
here is my sketch:
char auth[] = "GEraVZrPqUS3wMJnPJGuSUdCEAuVhtLP";
char ssid[] = "MikroTik Tesla";
char pass[] = "12345678";
char server[] = "10.5.51.5";
BLYNK_WRITE(V0)
String dat = param.asStr();
Serial.println("WebHook data:");
Serial.println(param.asStr());
Blynk.virtualWrite(V1, dat);
Blynk.begin(auth, ssid, pass, server, 8080);
// You can perform HTTPS requests even if your hardware alone can't handle SSL
// Blynk can also fetch much bigger messages,
// if hardware has enough RAM (set BLYNK_MAX_READBYTES to 4096)
//Blynk.virtualWrite(V0, "https://api.sunrise-sunset.org/json?lat=50.4495484&lng=30.5253873&date=2016-10-01");
Blynk.virtualWrite(V0, "10.5.51.5:8080/1ba32e9c834340ed83a795c083c03c4a/get/V28");
the serial output:
WebHook data:
["56.4"]
WebHook data:
["56.9"]
WebHook data:
["56.9"]
maybe you can try myString.toFloat()
Blynk_Coeur:
myString.toFloat()
thanks for reply. now showing 0.00 at serial output
BLYNK_WRITE(V0)
float myFloat = dat.toFloat();
Serial.println(myFloat);
Blynk.virtualWrite(V1, myFloat);
WebHook data:
0.00
You have to extract string 56.9 with substring function before converting
ErfanDL:
dat.toFloat();
like this? String dat = dat.toFloat();
This will not compiled!
error: conversion from 'float' to non-scalar type 'String' requested
I suggest you to cancel [" and β] before convertion
may be using dat.replace(β[", ββ) and dat.replace("]", ββ) ?
But I donβt understand why you get [β56.9β]
I tried https://fra1.blynk.cloud/external/api/get?token=XXXXXXXXXXXXXX&v3
and obtain the temperature without any bracket
what if you change datastream V1 to Double ?
Maybe this problem has been fixed in Blynk 2.0 ?
Double also displays the value 0.00
I am using Blynk 2.0
but why your V1 result is a string ?
Itβs legacy local server.
At least the Blynk.virtualWrite in the void loop is only flooding @ErfanDL βs local server
Not exactly sure why an API call is being used to get a Blynk virtual pin value from within a Blynk sketch though!
Iβm just testing something with my local server. I need to get the data of a Blynk server from Webhook on multiple nodemcus.
Thanks, my problem was solved with your suggestion.
BLYNK_WRITE(V0)
dat.replace("[", "");
dat.replace("]", "");
dat.replace("\"", "");
float myfl = dat.toFloat();
Serial.println(myfl);
Blynk.virtualWrite(V1, myfl);
WebHook data:
58.00
WebHook data:
56.90
It would be far more efficient to use Bridge, or a BLYNK_WRITE(Vpin) to do API calls that write the data values to virtual pins relating to the Auth tokens of the various NodeMCUs, rather than have each NodeMCU polling the Blynk server via an API call.
