hello … i’m new … I have a simple code for triggering the relay and I … touch button HTTM
to activate the relay should somehow double click … and I need one click … can help any
char auth[] = “be5ac8c181904d37bfe5b8bf5e12ae2d”;
char ssid[] = “ASUS”;
char pass[] = “11111111”;
const int ledPin1 = 12;//d6
const int ledPin2 = 13;//d7
const int ledPin3 = 14;
const int ledPin4 = 15;
const int btnPin1 = 5;
const int btnPin2 = 4;
const int btnPin3 = 9;
const int btnPin4 = 1;
void checkPhysicalButton();
int led1State = LOW;
int btn1State = HIGH;
int led2State = LOW;
int btn2State = HIGH;
int led3State = LOW;
int btn3State = HIGH;
int led4State = LOW;
int btn4State = HIGH;
BLYNK_CONNECTED() {
Blynk.syncVirtual(V12);
Blynk.syncVirtual(V13);
Blynk.syncVirtual(V14);
Blynk.syncVirtual(V15);
BLYNK_WRITE(V12) {
led1State = param.asInt();
digitalWrite(ledPin1, led1State);
BLYNK_WRITE(V13) {
led2State = param.asInt();
digitalWrite(ledPin2, led2State);
BLYNK_WRITE(V14) {
led3State = param.asInt();
digitalWrite(ledPin3, led3State);
BLYNK_WRITE(V15) {
led4State = param.asInt();
digitalWrite(ledPin4, led4State);
/// problem in this code
void checkPhysicalButton(){
if (digitalRead(btnPin1) == LOW) {
if (btn1State != LOW) {
led1State = !led1State;
Blynk.virtualWrite(V12, led1State);
btn1State = LOW;
btn1State = HIGH;
if (digitalRead(btnPin2) == LOW) {
if (btn2State != LOW) {
// Toggle LED state
led2State = !led2State;
// Update Button Widget
Blynk.virtualWrite(V13, led2State);
btn2State = LOW;
btn2State = HIGH;
if (digitalRead(btnPin3) == LOW) {
if (btn3State != LOW) {
// Toggle LED state
led3State = !led3State;
Blynk.virtualWrite(V14, led3State);
btn3State = LOW;
btn3State = HIGH;
if (digitalRead(btnPin4) == LOW) {
if (btn4State != LOW) {
// Toggle LED state
led4State = !led4State;
Blynk.virtualWrite(V15, led4State);
btn4State = LOW;
btn4State = HIGH;
pinMode(ledPin1, OUTPUT);
pinMode(btnPin1, INPUT_PULLUP);
pinMode(ledPin2, OUTPUT);
pinMode(btnPin2, INPUT_PULLUP);
pinMode(ledPin3, OUTPUT);
pinMode(btnPin3, INPUT_PULLUP);
pinMode(ledPin4, OUTPUT);
pinMode(btnPin4, INPUT_PULLUP);
timer.setInterval(500L, checkPhysicalButton);
