Really? Because before this I tried the water pump command only in 1 file. just water pump. and it works. But when I want to combine with rain sensor, dht11, soil sensor and pir sensor, the relay cannot open.
do you know how I’m supposed to re-arrange my code?
The /* is traeted as a block comment in the Arduino IDE.
Use // instead for a single like comment.
That’s correct. If you want to continuously monitor the PIR GPIO then you need to poll it with a timer running at maybe a 100ms interval.
Also, the DHT11 doesn’t like being sampled more tanh once every 10 seconds.
But if I put only blynk.run() and timer.run() in void loop, it will have other error.
I’m sorry for asking, can you teach me on how I am supposed to connect it with OneWire bus, Pete?
No, not if you use timers correctly, as explained in the “keep your void loop clean” document.
You aren’t, it’s not a OneWire relay. Simply connect it to a GPIO and remove the OneWire command for D2.
First of all, I’m sorry I dont know how to put my new code in the grey field like this ‘’ ‘’. Okay I already clean my void loop. But the water pump will turn on non-stop even I not push button on. same goes to my pir motion sensor. The pir sensor will turn on buzzer even I not touch it. Do you have any idea or solution? This is my code.
#include <DHT.h>
#include <OneWire.h>
#define ONE_WIRE_BUS D0
String apiKey = ""; //API Key from ThingSpeak channel
char auth[] = ""; //Authentication code sent by Blynk
char ssid[] = ""; //WiFi SSID
char pass[] = ""; //WiFi Password
//PIR
#define pirPin D1
int pirValue;
int pinValue;
const int buzzerPin = D7;
//SOIL MOISTURE
#define sensorPin D6
//RAIN
#define rainPin D5
int enable2 = D8;
int sensorState = 0;
int rainState = 0;
int lastState = 0;
int lastRainState = 0;
//DHT11
#define DHTPIN 2
#define DHTTYPE DHT11
DHT dht(DHTPIN, DHTTYPE);
//WATER PUMP RELAY
#define WATER_PUMP D2
boolean state = false;
//INPUT_OUTPUT
pinMode(sensorPin, INPUT);
pinMode(rainPin, INPUT);
pinMode(pirPin, INPUT);
pinMode(buzzerPin, OUTPUT);
pinMode(WATER_PUMP, OUTPUT);
pinMode(enable2, OUTPUT);
dht.begin();
timer.setInterval(1000L, sendTemps);
timer.setInterval(1000L, getPirValue);
sensors.begin();
//WATER_PUMP
BLYNK_WRITE(V1)
if (state == false) {
state == true;
digitalWrite(WATER_PUMP,HIGH);
Serial.println("You just watered your plant");
Blynk.notify("You just watered your plant.");
else {
state = false;
digitalWrite(WATER_PUMP,LOW);
//DHT11
void sendSensor()
float h = dht.readHumidity();
Blynk.virtualWrite(V6, t); //V6 is for Temperature
Serial.print("Current temperature = ");
Serial.print(t);
Serial.print(" ");
Blynk.virtualWrite(V5, h); //V5 is for Humidity
Serial.print("Current humidity = ");
Serial.print(h);
//SOIL
int sensor=0;
void sendTemps()
sensor=analogRead(A0);
float temp = sensors.getTempCByIndex(0);
Serial.println(temp);
Serial.print("Soil Moisture is : ");
Serial.println(sensor);
if (sensor > 900)
digitalWrite (WATER_PUMP, HIGH);
if (sensor > 900 && sensor < 950)
digitalWrite(WATER_PUMP, HIGH);
if (sensor < 700)
digitalWrite(WATER_PUMP, LOW);
Blynk.virtualWrite(V1, temp);
Blynk.virtualWrite(V2,sensor);
//MOTION
void getPirValue(void)
pirValue = digitalRead(pirPin);
Serial.println(pirValue);
if (pirValue == 0)
Serial.print("Motion detected");
Serial.print(pirValue);
Blynk.notify("Motion detected");
digitalWrite(buzzerPin, HIGH);
Blynk.virtualWrite(V0, pirValue); //V0 is for Motion
digitalWrite (buzzerPin, LOW);
delay(100);
//RAIN
rainState = digitalRead(rainPin);
Serial.println(rainState);
if (rainState == 0 && lastRainState == 0) {
Serial.println("Its Raining!");
Blynk.notify("Its Raining!");
digitalWrite(enable2, HIGH);
lastRainState = 1;
delay(100);
Serial.println("No Rains");
digitalWrite(enable2, LOW);
lastRainState = 0;
delay(100);
Unreadable
@kakngah please edit your post and put triple backticks at the beginning and end of your code so that it displays correctly.
Copy and paste these, if you can’t find the correct character on your keyboard.
alright… I already fix my post. Thank u pete. My problem is, I already clear my loop, but the water pump relay keeps turning on even if I not push the button. same goes to PIR sensor that detect motion, which it keeps turning on even I didn’t block it. Do you know how to fix this?
It seems that you aren’t interested in listening to the advice that you’re given.
Your code is littered with delays, even though the “keep your void loop clean” document explains that you shouldn’t do this.
You’re mixing GPIO numbers and “D” numbers in your code, even though @Blynk_Coeur advised against it
don’t mix pin Dpin and GPIO
You’re taking DHT readings every second, despite my advice to the contrary…
the DHT11 doesn’t like being sampled more than once every 10 seconds.
And you’re also polling your PIR once every second despite my advice to do this every 100ms…
In addition, your code is a mess, and as @Blynk_Coeur said…
Unreadable
It would be far better to group all of your variable declarations together at the top of the code and add comments to explain what each variable is for.
The variables that declare pin aliases should use GOPI numbers, not D numbers, with a comment saying what the corresponding D number is, and what type of sensor/device is connected to each of these pins.
The comments like…
//INPUT_OUTPUT void setup()
//WATER_PUMP void loop()
Are confusing and make it extremely difficult to track-down your void setup and void loop in the mess of code.
@PeteKnight @Blynk_Coeur Is it like this? I’m sorry, I try to understand and follow your advice. I’m very new to this. My problem is the water pump still running non-stop. and for PIR motion sensor, is it right I do like that?
#define ONE_WIRE_BUS 16 //GPIO16 or D0 is for OneWireBus
#include <DHT.h>
BlynkTimer timer; //Timer object
#define DHTPIN 2 //GPIO2 or D4 is for DHT11 sensor
#define pirPin 5 //GPIO5 or D1 is for PIR Motion sensor
#define WATER_PUMP 4 //GPIO4 or D2 is for Water Pump relay
#define sensorPin 12 //GPIO12 or D6 is for Soil moisture sensor
#define rainPin 14 //GPIO14 or D5 is for Rain sensor
#define DHTTYPE DHT11 //DHT11 temperature & Humidity sensor
DHT dht(DHTPIN, DHTTYPE); //DHT11 temperature & Humidity sensor
int pirValue; //For PIR Motion sensor value
int pinValue;
const int buzzerPin = 13; //GPIO13 or D7 is for buzzer connected with PIR Motion sensor
int enable2 = 15; //GPIO15 or D8 is for LED connected with Rain sensor
int sensorState = 0; //For soil sensor value
int rainState = 0; //For rain sensor value
int lastState = 0; //For rain sensor value
int lastRainState = 0; //For rain sensor value
boolean state = false; //For water pump to turn on or off
dht.begin();
timer.setInterval(10000L, sendSensor); //main function for DHT11 is called here
timer.setInterval(10000L, sendTemps); //main function for Soil is called here
timer.setInterval(100L, getPirValue); //main function for PIR is called here
sensors.begin();
void sendSensor() //main function for DHT11 sensor
Blynk.virtualWrite(V6, t); //V6 is for Temperature in Blynk App
Serial.print("Current temperature = "); //Value is printed on serial monitor
Serial.print(t);
Serial.print(" ");
Blynk.virtualWrite(V5, h); //V5 is for Humidity in Blynk App
Serial.print("Current humidity = "); //Value is printed on serial monitor
Serial.print(h);
int sensor=0;
void sendTemps() //main function for Soil sensor
sensor=analogRead(A0); //Get the soil sensor value
if (sensor > 900)
if (sensor < 700)
Blynk.virtualWrite(V1, temp); //Value is sent to the Blynk App
Blynk.virtualWrite(V2,sensor); //V2 for Soil sensor in Blynk App.
void getPirValue(void) //main function for Motion sensor
pirValue = digitalRead(pirPin); //Get the PIR motion sensor value
if (pirValue == 0)
Serial.print("Motion detected"); //Value is printed on serial monitor
Serial.print(pirValue); //Value is printed on serial monitor
Blynk.notify("Motion detected"); //Send notification to Blynk App
digitalWrite(buzzerPin, HIGH); //Buzzer on when detect motion
Blynk.virtualWrite(V0, pirValue); //V0 for PIR Motion sensor in Blynk
digitalWrite(buzzerPin, LOW); //Buzzer off when not detect motion
rainState = digitalRead(rainPin); //Get the Rain sensor value
if (rainState == 0 && lastRainState == 0) { //if detect any rain
Serial.println("Its Raining!"); //Value printed on serial monitor
Blynk.notify("Its Raining!"); //Send notification to Blynk App
digitalWrite(enable2, HIGH); //LED is on when detect rain
lastRainState = 1;
delay(100);
Serial.println("No Rains"); //if not detect any rain
digitalWrite(enable2, LOW); //LED off when not detect any rain
lastRainState = 0;
BLYNK_WRITE(V1) //V1 for Water Pump button in Blynk
state = true;
digitalWrite(WATER_PUMP,HIGH); //Water pump will turn On
Serial.println("You just watered your plant"); //Value is printed on serial monitor
Blynk.notify("You just watered your plant."); //Send notification to Blynk App
else {
state = false;
digitalWrite(WATER_PUMP,LOW); //Water pump will turn Off
if (state == false) { state == true;
One issue I see…
The first use of the double == is correct, as a comparator
The second use is not correct, it should be a single = to assign a value
timer.setInterval(10000L, sendSensor); //main function for DHT11 is called here timer.setInterval(10000L, sendTemps); //main function for Soil is called here timer.setInterval(100000L, getPirValue); //main function for PIR is called here
Another issue is that all these timers call their respective functions at the same time (the 3rd one every 10th time the others run). These are not multitasking devices ![]()
And then there are all the delay() commands in your code… not good
I would recommend timeout timers and flags to avoid too frequent use of notifications. But then that is more programming you need to learn and you need to fix what you have. I would suggest avoiding the notifications altogether until you have the rest figured out.
@PeteKnight has already provided a topic on timers and the link was posted above. You NEED to read it.
Got it. I did not realize it. Thank u so much @Gunner ![]()
delay()commands in your code… not good
Meaning that all the delay() part must be removed isn’t?
Does this mean I have to use timer.timeout instead of timer.setInterval? or combine it? I already read it but I quite confused ![]()
Yes , you can’t use delays with Blynk
Your code must be modified like this :
sensors.begin();
dht.begin();
timer.setInterval(10250L, sendTemps); //main function for Soil is called here
timer.setInterval(500L, getPirValue); //main function for PIR is called here
lastRainState = 1;
//delay(100); ----> have to be removed
Okay, I have deleted all the delays in my code. Now my water pump can work!! Thank u so much for your help ![]()
Serial.begin(9600); Blynk.begin(auth, ssid, pass); sensors.begin(); dht.begin(); timer.setInterval(10000L, sendSensor); //main function for DHT11 is called here timer.setInterval(10250L, sendTemps); //main function for Soil is called here timer.setInterval(500L, getPirValue); //main function for PIR is called here //***** digitalWrite(enable2, HIGH); //LED is on when detect rain lastRainState = 1; //delay(100); ----> have to be removed
For this code, the DHT temperature & humidity sensor only will upload after 10seconds ? same goes to soil sensor?
Removed, yes…ish… but more accurately, replaced.
I will do this as pseudocode as I am busy at moment.
In place of a Delay for X amount of time use a timeout function…
If "notification flag" is not set, then... (Else skip this function)
- Set "notification flag" to prevent further looping of this function
- Notify
- Start timeout timer for X amount of time...
- At end of timeout timer...
- Clear "notification flag" to allow next loop of this function
@kakngah I’d suggest that you don’t keep going back and editing the code that you’ve previously posted, instead post the modified code, along with a quick summary of what you’ve done, and - most importantly - a summary of which functions are working correctly and which are not.
You still have some variable being declared in random places…
int sensor=0; void sendTemps()
and your variable names aren’t exactly very descriptive, and you have a OneWire object called sensors and a variable called sensor which is potentially confusing. If the variable sensor is actually a function of the soil moisture then call it soil_moisture.
and if temp is the soil temperature then call it soil_temperature…
void sendTemps() //main function for Soil sensor { sensor=analogRead(A0); //Get the soil sensor value sensors.requestTemperatures(); float temp = sensors.getTempCByIndex(0);
Your void getPirValue(void) function (the void in the brackets isn’t needed by the way) runs straight into the code that checks the rainstate, but the wat that the indentation is arranged doesn’t make this clear, and neither does the comment at the top of the `void getPirValue(void), or the name of the function its self.
This piece of code if very confusing to me, as you are using reversed logic for the rainState (nortmally 0 = false and 1 = true), but you are using the opposite logic for lastRainState…
if (rainState == 0 && lastRainState == 0) { //if detect any rain Serial.println("Its Raining!"); //Value printed on serial monitor Blynk.notify("Its Raining!"); //Send notification to Blynk App digitalWrite(enable2, HIGH); //LED is on when detect rain lastRainState = 1; delay(100); } else { Serial.println("No Rains"); //if not detect any rain digitalWrite(enable2, LOW); //LED off when not detect any rain lastRainState = 0; }
You’d be better invbertiung the reading from your rain sensor like this…
rainState = !rainState; // Invert the value so 1 = raining
I don’t see the need to use any delays or replacement timeout timers in your code.
