tomixps
September 23, 2020, 7:21pm
1
If V1 is 1, turn on relay D3 and after delay (500) set pin V1 to 0 and turn off relay D3 after delay (500).
Something’s not working for me.
void przekaznik()
if ( V1 == 1 )
digitalWrite(D3,HIGH);
delay(500);
Blynk.virtualWrite(V1,0);
else {
delay(500);
digitalWrite(D3,LOW);
Gunner
September 23, 2020, 8:07pm
2
tomixps:
if ( V1 == 1 )
This means nothing to Blynk… you must use Blynk functions like BLYNK_WRITE(V1)
in order to respond to vPin state changes.
And it is bad form to use delay()
with Blynk… use timers instead.
#12 - Timers simplified… perhaps…
Some have a difficult time understanding timers… and since this is a fundamental building block of Blynk… I buried this reference in the middle of this entire topic Well anyhow…
This is a “real world” timer example where i am using two timers to alternately turn ON and OFF an LED… yes, there are many ways to do this, but this example is all about timers.
The first timer will run it’s assigned function 500ms (1/2 second) after boo…
A Lambda shortcut version of a non-blocking timeout timer command/function works nicely.
// Timed Lambda Function - Timeout countdown
timer.setTimeout(500L, []() { // Run following command(s) after 500ms
}); // END Timer Function
tomixps
September 24, 2020, 4:04pm
3
I have something wrong; /
char auth[] = "";
char ssid[] = "";
char pass[] = "";
int Value;
int Relay = D3;
BLYNK_WRITE(V2)
Value = param.asInt();
if ( Value == 1 )
timer.setTimeout(500L, RelayON);
timer.setTimeout(600L, RelayOFF);
timer.setTimeout(700L, RelayON);
timer.setTimeout(800L, RelayOFF);
timer.setTimeout(900L, RelayON);
Blynk.virtualWrite(Value,0);
Blynk.syncVirtual(V2);
else {
timer.setTimeout(1200L, RelayOFF);
BLYNK_CONNECTED () {
Blynk.syncAll ();
pinMode(Relay,OUTPUT);
digitalWrite(Relay,LOW);
void RelayON() {
digitalWrite(Relay, HIGH);
void RelayOFF() {
digitalWrite(Relay, LOW);
What is it EXACTLY that you are now trying to achieve, and what results are you actually seeing?
Why do yo now have multiple timeout timers when you’ve said that your aim is to…
What is the purpose of this line:
tomixps:
tomixps
September 24, 2020, 5:45pm
5
It works for me but I would like to change “delay” on “timer”
char auth[] = "";
char ssid[] = "";
char pass[] = "";
int Value;
int Relay = D3;
BLYNK_WRITE(V2)
Blynk.syncAll ();
timer.setInterval(500L, Relay_1);
void Relay_1()
if ( Value == 1 )
digitalWrite(Relay,HIGH);
delay(500);
delay(500);
delay(500);
delay(500);
delay(500);
Blynk.virtualWrite(V2,0);
Blynk.syncVirtual(V2); /// Virtual pin update
delay(500);
else {
Now it’s 100% clear (not)!
Neither do I.
I’d asked you to explain…
and your reply was…
I have no idea what this means, so I can’t help until you explain in MUCH more detail.
tomixps
September 26, 2020, 4:22pm
9
I want the relay to work intermittently ON-OFF-ON-OFF-ON-OFF. I don’t know how to replace “delay (500)” with “SimpleTimer”
Go back to your previous code.
Your problem there was that you had multiple timeout timers that I think l you were expecting would run one after another.
Because they are non blocking the timers run at the same time, so your LED would probably have turned on for 500ms, off for 100ms, on for 100ms etc.
It’s better to trigger the next timeout timer at the end of the function that is called when the first timer ends.
tomixps
September 26, 2020, 5:28pm
11
Are you able to write me an example how to do it?
I’m not going to write your code for you, but other forum members may wish to do that.
If you have a go at writing it yourself, and can articulate what it is that you are trying to achieve and in which ways the code is failing to do this, then I’d be happy to critique your code and point you in the right direction.
tomixps
September 27, 2020, 2:00pm
13
Now it works for me, but it does not turn off the relay and does not change the state of V2 = 0
char auth[] = "";
char ssid[] = "";
char pass[] = "";
int SWITCH;
#define Relay D3
Blynk.syncAll ();
pinMode(Relay, OUTPUT);
BLYNK_WRITE(V2)
SWITCH = param.asInt();
if (SWITCH == 1 ) {
timer.setTimer(1000L, RelayON, 2);
Blynk.virtualWrite(SWITCH,0);
Blynk.syncVirtual(SWITCH);
void RelayON() {
timer.setTimeout(500L, RelayOFF);
void RelayOFF() {
I’ve asked you before what the purpose of this line is, and you haven’t answered that question.
What it actually does is to trigger BLYNK_WRITE(V1) which doesn’t exist in your code.
Also, this…
Will set the widget attached to V1 (if there is one) to 0 or off. I doubt if that is what you want.
tomixps
September 27, 2020, 7:04pm
17
i want to set pin v2 to 0
So it has to be ?
BLYNK_WRITE(V2)
if (SWITCH == 1 ) {
tomixps:
Why do you want to force the BLYNK_WRITE(V2) callback to trigger again, passing a param.asInt value of 0 to the function? It makes no sense and serves no productive purpose.
tomixps
September 27, 2020, 8:15pm
19
PeteKnight:
p
So this is how it should be?
But how to turn on and off the relays ON (1sec) OFF (1sec) ON (1sec) OFF?
BLYNK_WRITE(V2)
if (SWITCH == 1 ) {
What is the relay attached to D3 doing at the moment?
