RedBear Duo question
Hello all,
I just got the RedBear Duo board, the little thing looks promising, no as ease or mature as the ESP8266, but it works.
Somehow I got the WiFI Blynk example working, but I cannot get the Blynk.virtualWrite going, I get an error saying the virtual pin I am trying to use is not declare: ā€˜V35ā€™ was not declared in this scope
I am using the latest Blynk 0.4.3
Here is the example I am using:
#include <BlynkSimpleRedBear_Duo.h>
int x = 10;
// Choose wifi_sec from WPA2, WPA, or WEP
char pass[] = "YourPassword";
int wifi_sec = WPA2;
//SYSTEM_MODE(AUTOMATIC);
SYSTEM_MODE(MANUAL);
  delay(5000);
  WiFi.on();
  WiFi.setCredentials(ssid, pass, wifi_sec);
  WiFi.connect();
  Blynk.begin(auth);
  // Or specify server using one of those commands:
  //Blynk.begin(auth, "blynk-cloud.com", 8442);
  //Blynk.begin(auth, server_ip, port);
Blynk.virtualWrite(V35, x); /* <== this is not working */
Guys, gals,
Never mind, taking the ā€œVā€ away solved the problem. I am so used to the ESP8266, I always use the Blynk.virtualWrite with the ā€œVā€
@italex33 you probably need to enable this feature :
#define BLYNK_USE_128_VPINS
AS by default we have 32 Virtual pins. @vshymanskyy please update doc. It is not documented anywhere.
Thank you, Dmitriy. if I add the DEFINITION as you indicate It works as I expect, I mean using the V35. I ran out of physical pins using the ESP8266, so I am looking into this new kid of the block. Anyway, problem solved. Blynk is addictive!
