Redbear BLE Nano I2C
I am prototyping a project using the Redbear BLE Nano v1.5 and would like to be able to use an I2C interface. However, when I load my sketch with the code (see below) the Blynk app does not detect the device. On the other hand, if I launch another app such as the nRF Connect app from Nordic, the device shows up in the scanner list. Another notable item is that when I load the example Blynk sketch for the BLE Nano, the device is detected by the Blynk app.
Sketch Code:
  • Blynk is a platform with iOS and Android apps to control
  • Arduino, Raspberry Pi and the likes over the Internet.
  • You can easily build graphic interfaces for all your
  • projects by simply dragging and dropping widgets.
  • Downloads, docs, tutorials: http://www.blynk.cc
  • Blynk community: http://community.blynk.cc
  • Social networks: Blynk
  •                           http://twitter.com/blynk_app
  • Blynk library is licensed under MIT license
  • This example code is in public domain.
  • This example shows how to use RedBearLab BLE Nano
  • to connect your project to Blynk.
  • NOTE: BLE support is in beta!
#include <Wire.h>
#include <BlynkSimpleRedBearLab_BLE_Nano.h>
#include <BLE_API.h>
#define SCL 3
#define SDA 2
char auth = “My Auth”;
uint8_t device_name = “Blynk-I2C”;
Wire.begin(SCL, SDA, TWI_FREQUENCY_100K);
delay(100);
ble.init();
ble.gap().accumulateAdvertisingPayload(GapAdvertisingData::BREDR_NOT_SUPPORTED);
ble.gap().accumulateAdvertisingPayload(GapAdvertisingData::SHORTENED_LOCAL_NAME,
device_name, sizeof(device_name) - 1);
ble.gap().setDeviceName(device_name);
ble.gap().setTxPower(4);
// Add Blynk service…
Blynk.begin(auth);
ble.gap().setAdvertisingType(GapAdvertisingParams::ADV_CONNECTABLE_UNDIRECTED);
ble.gap().setAdvertisingInterval(Gap::MSEC_TO_GAP_DURATION_UNITS(1000));
ble.gap().setAdvertisingTimeout(0);
ble.startAdvertising();
Serial.println(“Waiting for connections…”);
