Socat never connects, exits, and continually loops through “Reconnecting in 3s…”.
Thank you to anyone who reads this, your help is appreciated!
Same issue as this previous post.
https://community.blynk.cc/t/reconnecting-in-3s-please-help/895
I have followed all instructions, which are fantastic btw, really great, including the video on this page
Arduino USB Serial
Arduino Uno via USB Serial (Mac OS Sierra)
MyComputer:scripts user$ ./blynk-ser.sh
1 ports found. You can specify port manually using -c option
Select serial port [ /dev/tty.usbserial-A403CUA8 ]: /dev/tty.usbserial-A403CUA8
Resetting device /dev/tty.usbserial-A403CUA8...
[ Press Ctrl+C to exit ]
Connecting: GOPEN:/dev/tty.usbserial-A403CUA8,raw,echo=0,clocal=1,cs8,nonblock=1,ixoff=0,ixon=0,ispeed=9600,ospeed=9600,crtscts=0 <-> openssl-connect:blynk-cloud.com:8441,cafile=/Users/user/Documents/Arduino/libraries/Blynk/scripts/certs/server.crt,nodelay
2017/12/07 13:30:11 socat[4395] N opening character device "/dev/tty.usbserial-A403CUA8" for reading and writing
2017/12/07 13:30:11 socat[4395] N opening connection to LEN=16 AF=2 45.55.96.146:8441
2017/12/07 13:30:12 socat[4395] N successfully connected from local address LEN=16 AF=2 10.0.0.29:51782
2017/12/07 13:30:13 socat[4395] N trusting certificate, commonName matches
2017/12/07 13:30:13 socat[4395] N SSL connection using ECDHE-RSA-AES128-GCM-SHA256
2017/12/07 13:30:13 socat[4395] N SSL connection compression "none"
2017/12/07 13:30:13 socat[4395] N SSL connection expansion "none"
2017/12/07 13:30:13 socat[4395] N starting data transfer loop with FDs [5,5] and [8,8]
2017/12/07 13:30:35 socat[4395] N socket 2 (fd 8) is at EOF
2017/12/07 13:30:36 socat[4395] N exiting with status 0
Reconnecting in 3s...
I feel like I’m so close to connecting with the app, but not at all. There was another post that mentioned something about SoftwareSerials but I have no idea if this is still related.
