Reboot when Blynk connection fails
which could be an elegant and reliable way to reboot device in case of reconnections fail ?
Hey there,
Please give more details like the board you’re using, are you using blynk edgent, etc…
This might help you
https://docs.blynk.io/en/blynk.edgent/api/reboot
Esp32 but I’m not using Edgent because I found several bugs:
it connects to wifi but not to Blynk cloud, it seems impossible to add to my account so I solved using last way to connect.
Use ESP.restart();
Check the link in the previous post
Can you explain please ?
Have you defined the template ID and device name ?
Sure.
I wrote to support (Mark) he told me that there is a bug and sometimes the memory is not cleared in the right way so he suggests to use esptool
Use the esptool to erase the flash then try again
