I am using the RTC and time widget for triggering on and off a relay. My problem is that I want the RTC to work even if the internet connection drops, and when there is connection again to resync time with the servers. This is my schematic:
#include <TimeLib.h>
#include <WidgetRTC.h>
// Esp8266 pins.
#define ESP8266_GPIO2 2 // Blue LED.
#define ESP8266_GPIO4 4 // Relay control.
#define ESP8266_GPIO5 5 // Optocoupler input.
#define LED_PIN ESP8266_GPIO2
char auth[] = "...";
const char ssid[] = "...";
const char password[] = "...";
// Flag for sync on re-connection.
bool isFirstConnect = true;
volatile int relayState = LOW; // Blynk app pushbutton status.
volatile int inputState = LOW; // Input pin state.
WidgetRTC rtc;
pinMode( ESP8266_GPIO4, OUTPUT ); // Relay control pin.
pinMode( ESP8266_GPIO5, INPUT_PULLUP ); // Input pin.
pinMode( LED_PIN, OUTPUT ); // ESP8266 module blue LED.
digitalWrite( LED_PIN, LOW ); // Turn on LED.
Blynk.begin( auth, ssid, password ); // Initiate Blynk conection.
digitalWrite( LED_PIN, HIGH ); // Turn off LED.
setSyncInterval(10 * 60); // Sync interval in seconds (10 minutes)
timer.setInterval(10000L, clockDisplay);
BLYNK_CONNECTED() {
rtc.begin();
if (isFirstConnect) {
Blynk.syncAll();
isFirstConnect = false;
// Blynk app relay command.
BLYNK_WRITE( V0 ) {
if ( param.asInt() != relayState ) {
relayState = !relayState; // Toggle state.
digitalWrite( ESP8266_GPIO4, relayState ); // Relay control pin.
// Debounce input pin.
int DebouncePin( void ) {
// Read input pin.
if ( digitalRead( ESP8266_GPIO5 ) == HIGH ) {
// Debounce input.
delay( 25 );
return HIGH;
return LOW;
void clockDisplay()
Blynk.virtualWrite(V1, currentTime);
Blynk.virtualWrite(V2, currentDate);
I wanted to know if anyone has done this before and could help me with his schematic. Thanks!
Then use a real RTC Module in your circuit and don’t use the RTC widget which will require a Server to sync with
What I want to do is achievable with a little programming to check if connection is dropped and start a local time variable on ESP8266’s memory and switch back to RTCs widget time when the connection is re-established… I thought I’d ask here first in case anyone has done this before. Using a RTC module is not a solution for me.
Probably better to run a local server.
I leave my final code in case someone needs it. The Blynk app program needs two Value Display elements (this elements would be necessary for the offline operation, they are assigned to virtual pins 10 and 11), one timer (on virtual pin 1) this would turn on/off the relay if there’s internet connection. And an RTC element. Notice that this two elements (timer and value display) should have the same on/off time set up so that there’s no inconsistency (I could have just used the timer and read the values from it to avoid setting up 2 times the on/off moment, but I used this other approach for testing purposes)
// Esp8266 pins.
#define RELAY_PIN V0
#define INICIO V10
#define FIN V11
WidgetRTC rtc;
// para detectar horarios de inicio y fin de relay
long startTimeInSecs;
long endTimeInSecs;
//start time
long shs;
long smins;
long ssecs;
//end time
long ehs;
long emins;
long esecs;
//Serial.begin(9600);
digitalWrite( LED_PIN, LOW ); // Turn off LED.
digitalWrite( LED_PIN, HIGH ); // Turn on LED.
setSyncInterval(720 * 60); // Sync interval in seconds (1 dia)
timer.setInterval(60000L, clockDisplay); // Cada 60 segundos actualizar
// This function runs every time Blynk connection is established.
BLYNK_CONNECTED() {
if ( isFirstConnect ) {
Blynk.syncAll();
rtc.begin();
BLYNK_WRITE( RELAY_PIN ) {
// Para leer hora de inicio
BLYNK_WRITE(INICIO) {
startTimeInSecs = param[0].asLong();
shs = startTimeInSecs/3600;
smins = (startTimeInSecs/60) - (60*shs);
ssecs = (startTimeInSecs) - ((60*smins) + (3600*shs));
//Serial.println("Inicio: "+String(shs)+":"+String(smins)+":"+String(ssecs));
// Para leer hora de fin
BLYNK_WRITE(FIN) {
endTimeInSecs = param[0].asLong();
ehs = endTimeInSecs/3600;
emins = (endTimeInSecs/60) - (60*ehs);
esecs = (endTimeInSecs) - ((60*emins) + (3600*ehs));
//Serial.println("Fin: "+String(ehs)+":"+String(emins)+":"+String(esecs));
void clockDisplay()
//Serial.println("HORA ACTUAL: "+currentTime);
// Main program loop.
boolean isconnected = Blynk.connected();
if (!isconnected) {
if ((hour() == shs) and (minute() == smins) and (second() == ssecs)) {
digitalWrite( ESP8266_GPIO4, HIGH );
if ((hour() == ehs) and (minute() == emins) and (second() == esecs)) {
digitalWrite( ESP8266_GPIO4, LOW );
Hey, can you show me to configure for this program on blynk app, i’m new to coding so i not much understand this code, like why v0,v10,v11,gpio02,gpio04 pins uses?, please help me.
