Ready to teach my computer to fly... HELP
Help me please, trying to get this project off the ground, I feel like it should be more simple than this… I got the sketch to compile, loaded onto my MKR1000 but no joy. The app says my project is not on line. Auth code, and home wifi data is correct in sketch. What am I missing here?
#include <Adafruit_BMP280.h>
#include <WiFi101.h>
#include <BlynkSimpleMKR1000.h>
char auth[] = "Q4RG3xxxxxxxxxxxxxxxxxxxxxxxxGu8ipgh";
char ssid[] = "skynetvan213";
char pass[] = "xxxxxxxxxxxxxx462";
#define BMP_SCK  (5)
#define BMP_MISO (2)
#define BMP_MOSI (4)
#define BMP_CS   (1)
Adafruit_BMP280 bmp; // I2C
//Adafruit_BMP280 bmp(BMP_CS); // hardware SPI
//Adafruit_BMP280 bmp(BMP_CS, BMP_MOSI, BMP_MISO,  BMP_SCK);
    Serial.println(F("BMP280 test"));
  if (!bmp.begin()) {
    Serial.println(F("Could not find a valid BMP280 sensor, check wiring!"));
    while (1);
  /* Default settings from datasheet. */
  bmp.setSampling(Adafruit_BMP280::MODE_NORMAL,     /* Operating Mode. */
                  Adafruit_BMP280::SAMPLING_X2,     /* Temp. oversampling */
                  Adafruit_BMP280::SAMPLING_X16,    /* Pressure oversampling */
                  Adafruit_BMP280::FILTER_X16,      /* Filtering. */
                  Adafruit_BMP280::STANDBY_MS_500); /* Standby time. */
     Serial.print(F("Temperature = "));
    Serial.print(bmp.readTemperature());
    Serial.println(" *C");
    Serial.print(F("Pressure = "));
    Serial.print(bmp.readPressure());
    Serial.println(" Pa");
    Serial.print(F("Approx altitude = "));
    Serial.print(bmp.readAltitude(1013.25)); /* Adjusted to local forecast! */
    Serial.println(" m");
    Serial.println();
    delay(2000);
@emtjim the first thing that you’re missing is the triple backticks at the beginning and end of your code that make it display correctly on this forum.
Please edit your post with the pencil icon at the bottom, and add the triple backticks.
Got it thank you… Better?
Jim
What are you seeing in your serial monitor?
Have you read and understood this:
Pete,
I think I need to be more clear, I know very little of how this works. I really only need to get this to work as I don’t intend on multiple projects. So I’m learning slowly…
I’m not seeing a thing when I open the monitor, Im not sure the sketch is making it past the setup. I would think at a minimum I would see the MKR 1000 link up with the app in Blynk and maybe get corrupt data but I can’t even get a link in to Blynk…
and I did read the suggested article you referenced.
Jim
Have you tried it without the BMP code? If there is a BMP problem the setup() will stop and you wont get to Blynk.
Also even with a BMP error you should still see this in the Serial Monitor.
Simplify your sketch and add components one at a time.
billd
Is there any message on your serial port when it run? Such as “BMP280 test”? You can init Blynk.begin() first before you test bmp.begin().
Thanks Bill,
I did pare down to one sensor (BME280) the make things a bit easier. Still working on the Blynk connection issue and will look at the BMP code. I know I have connectivity as I had to run a I2C scanner to get the sensor address. Unfortunately the 1000 can’t find the sensor. but I’m getting there.
Jim
Hi! Can you try to upload this first to your board and check what will print on serial?
  if (!bmp.begin()) {
    while (1);
    Serial.println();
    delay(2000);
it should work fine with this… then you know your sensor is working properly… then you can continue with blynk implementation…
then you can try with this sketch:
#include <BlynkSimpleWiFiShield101.h>
char pass[] = "YourPassword";
void sendSensorData()
  float t = bmp.readTemperature();
  float p = (float) bmp.readPressure();
  float a = bmp.readAltitude(1013.25);
  Blynk.virtualWrite(V0, t);
  Blynk.virtualWrite(V1, p);
  Blynk.virtualWrite(V2, a);
  bmp.begin();
  timer.setInterval(2000L, sendSensorData);
it sends values to V0, V1 and V2 virtual pins on your app… so, you need to type in your wifi acc and your auth token, and adjust your value labels accordingly, on interval time you need to select PUSH, and assign each value label or whatever widget to each of virtual pins… note that the second code doesnt print anything in serial, if you want you can add debug yourself…
Voo,
Thanks for the help! I will absolutely give this a shot tonight and let you know what happens.
Jim
Did you got it?
I got it! I had to redo the sketch with less junk in it but in the end it works great and in fact it worked so well I have added two additional sensors. Next step is a load cell and I’m done. Thanks for the input.
Jim
