Reading Digital Pin using Bridge
My idea is creating a Wifi Remote Device (ESP8266) to control other ESP8266 (remote), I have succeed to push (write) one value to Digital Pin on remote ESP, unfortunately I can not find a way to read the remote Digital Pin … This (remote digital pin) value is needed since I want to create a toggle mechanism …
Further more on the remote device to preserve the batt I will shutdown the device in any given time …
Any suggestion for work around?
 *     BLYNK with RaspBerry Local Server
 *     192.160.0.XX - My_IoT
 *     Rev 1
#define BLYNK_MAX_SENDBYTES 1200
#define BLYNK_PROPERTY // Comment this out to disable Blynk.setProperty
#include <TimeLib.h>
#include <WidgetRTC.h>
#include <TimeLord.h>
// ************** OTA *****************
#include <ESP8266mDNS.h>
#include <WiFiUdp.h>
#include <ArduinoOTA.h>
// ---------------- CRENDENTIAL and Other Param -------------------------------------------------------------
const char ssid[] = "wifi";
const char pass[] = "passwd";
const char blynk_server[40] = "ip";
const char auth[] = "auth1"; // Wifi Remote
const char auth_bridge[] = "auth2"; // Lt.2
const char OTA_Hostname[] = "myesp-WifiRemote";
#define DigitalPinButton D1 // GPIO_5
#define DigitalPinInternalLED D4
#define DigitalPinLED D3 // GPIO_0
#define DigitalPinBridgeLED D5 // GPIO_14
#define VirtualPinBridgeLED V5 // GPIO_14
ADC_MODE(ADC_VCC);
WidgetRTC rtc;
WidgetBridge bridge_lt2(V0);
const int DebounceCounterMAX = 5;
// boolean FirstConnection = true;
boolean LastNetworkConnectionState = false;
boolean LampStateHIGH = false;
int DebounceCounter = 0;
                            STARING BLYNK FUNCTiON
BLYNK_CONNECTED() { // -- Executed every Blynk connected to internet
 bridge_lt2.setAuthToken(auth_bridge);
 if (FirstConnection) {
   ToggleSwitchLamp();
   FirstConnection = false;
BLYNK_WRITE(V2) { //-- Button Widget for Lamp 1
  int i =  param.asInt();
void ToggleSwitchLamp() {
  LampStateHIGH = !LampStateHIGH;  // flip LampState
  if (LampStateHIGH) {
    bridge_lt2.virtualWrite(VirtualPinBridgeLED, HIGH);
  else {
    bridge_lt2.virtualWrite(VirtualPinBridgeLED, LOW);
void Timer_ReadButtonDebounce ()
  int ButtonValue = digitalRead(DigitalPinButton); // Touch Sensor Switch
  if (ButtonValue == 1) {
    DebounceCounter++;
    if (DebounceCounter == DebounceCounterMAX) ToggleSwitchLamp();  // == non repeatable; >= reapetable
  else DebounceCounter = 0;
void TimerCheckNetworkConnection()
  boolean CurrentNetworkConnectionState = Blynk.connected();
  if (CurrentNetworkConnectionState) {
    if (CurrentNetworkConnectionState != LastNetworkConnectionState) digitalWrite(DigitalPinInternalLED, HIGH);
  else {
    if (CurrentNetworkConnectionState != LastNetworkConnectionState) digitalWrite(DigitalPinInternalLED, LOW);
  LastNetworkConnectionState = CurrentNetworkConnectionState;
                            STARING SETUP & LOOP FUNCTiON
  pinMode(DigitalPinButton, INPUT);
  pinMode(DigitalPinInternalLED, OUTPUT); // Internal LED (Blink network)
  digitalWrite(DigitalPinInternalLED, LOW); // initial Set internal LED Off
  ConnectWifi();
  Blynk.config(auth,blynk_server,8080);
  timer.setInterval(10L, Timer_ReadButtonDebounce); // Read phisical button every 100 milisecond
  timer.setInterval(250L, TimerCheckNetworkConnection); // Blink while not connected to WiFi
  Init_ArduinoOTA();
  ArduinoOTA.handle();
Did you try to read the Digital Pin firstly from its board and transfer the data into Virtual Pin to be sent to the Remote device? Give it a try…
Sure … Nice suggestion, I can create a trigger for the remote control device (master) to ask the slave device to copy the digital pin state to the master virtual pin… but yet I have no clue how to read the virtual pin?
Ummmhh … maybe I can use BLYNK_WRITE(VirtualPin)
Ok let me try … thanks for the suggestion @psoro
its not possible to read a pin directly, the only method is blynk.sync(pin) in combination with blynk_write(pin) the sync will force the write to run.
Note that if you update a pin remotely it will trigger blynk_write for that pin locally, just keep in mind that you use a bridge to update the remote pin.
You know about Espressif Systems’ ESP.now communication? (they must be near around one of the other to work but no internet is needed)
The other device I want to controlled is running Blynk apps… I don’t think Bynk is supporting ESP.now yet… :slight_smile:
I know, but i was talking that «if the devices are near» you can use ESP.now to make a “local communication protocol” to use when the internet connection is down.
