Hi friends. I need to reading the humd and temp value of Nodemcu 1 to Nodemcu 2. but I can’t reading the value from the Nodemcu 1. I want to showing the humd+temp to V125. here my sketch:
Nodemcu 1 sender:
#include <Wire.h>
#include <DFRobot_SHT20.h>
char auth[] = "eoL0UKzvBBEIhsbFH5shIiqn1jw3D80v";
char ssid[] = "MikroTik Tesla";
char pass[] = "12345678";
char server[] = "10.5.51.5";
WidgetBridge bridge1(V100);
DFRobot_SHT20 sht20;
BLYNK_CONNECTED()
bridge1.setAuthToken("yOXPQ12Lpju7po5qUm54jJfW7dALv-Rh");
Blynk.begin(auth, ssid, pass, server, 8080);
sht20.initSHT20();
delay(100);
sht20.checkSHT20();
timer.setInterval(2000L, TH);
timer.setInterval(30 * 1000, reconnectBlynk);
void TH()
float humd = sht20.readHumidity();
Blynk.virtualWrite(V127, humd);
bridge1.virtualWrite(V127, humd);
float temp = sht20.readTemperature();
Blynk.virtualWrite(V126, temp);
bridge1.virtualWrite(V126, temp);
void reconnectBlynk() {
if (!Blynk.connected()) {
Serial.println("Lost connection");
if (Blynk.connect()) {
Serial.println("Reconnected");
else {
Serial.println("Not reconnected");
if (Blynk.connected()) {
Nodemcu 2 receiver:
char auth[] = "yOXPQ12Lpju7po5qUm54jJfW7dALv-Rh";
BLYNK_CONNECTED()
bridge1.setAuthToken("eoL0UKzvBBEIhsbFH5shIiqn1jw3D80v");
int humd = (V127);
int temp = (V126);
timer.setInterval(2000L, TH2);
void TH2()
Blynk.virtualWrite(V125, humd + temp);
thanks.
