Read only Project Sharing
Congratulation, the read only sharing is on today’s release. But I could not get it to work yet, it is giving message ‘It is not a public shared dashboard’. I’m using particle photon and ESP8266, install new library from Github today.
Sharing mode at the moment works only for new users that doesn’t use Blynk. So you need to do scan from login page in order to make it work. Later it will be available also within existing user profile.
@akm17 added brief “How To” http://docs.blynk.cc/#sharing-dashboard-sharing-with-auth-token
Yes it works from to login page, Thanks!
Can I say that the way you remove the canvas dot and tidy up the line on user screen is superb, looks very professional and definitely sell-able apps. I hope you can get the iOS version running when the subscription charge started. Many thanks, and all the best for the subscription model approach.
