Hello. I have a problem with reach data to ntc10k temperature sensor on blynk.
I reach some data, but is completely wrong, and is no constant (i reach 30 degrees, a second later -20 degrees, for example)
There is my code. Honestly, I dont know what i do wrong…
Thank you so much for help :)))
#define BLYNK_TEMPLATE_ID "TMPL-3eq93fZ"
#define BLYNK_DEVICE_NAME "test"
#define BLYNK_AUTH_TOKEN "39aYTJHdg5kfgHYamwZL3siPqJl2Nrv_"
#include <WiFi.h>
#include <WiFiClient.h>
#include <BlynkSimpleEsp32.h>
char ssid[] = "Tenda_11EB10";
char pass[] = "faraparola";
void myTimerEvent()
Blynk.virtualWrite(V1, millis() / 1000);
void sensorDataSend()
int ThermistorPin = 32;
int Vo;
float A = 10000;
float logC, C, T ;
float c1 = 1.009249522e-03, c2 = 2.378405444e-04, c3 = 2.019202697e-07;
float c4 = 1.009249522e-03, c5 = 2.378405444e-04, c6 = 2.019202697e-07;
Vo = analogRead(ThermistorPin);
C = A * (1023.0 / (float)Vo - 1.0);
logC = log(C);
T = (1.0 / (c1 + c2*logC + c3*logC*logC*logC));
T = T - 273.15;
Blynk.virtualWrite(V1, T);
//Blynk.begin(auth, ssid, pass, "blynk.cloud", 80);
timer.setInterval(5000L, sensorDataSend);
