Read breaker - widgetLED
Hello
I have a problem. I want to use widgetLED reading of the limit switch. I can not write code to read me two limit switches.
// Include the libraries we need
#include <OneWire.h>
// Data wire is plugged into port 2 on the Arduino
#define ONE_WIRE_BUS 2
char auth[] = "kod";
int pin = D4; // Pin cyfrowy krancówka
WidgetLED led1(V2); // Pin wirtualny krancowy
pinMode(pin,INPUT);
Blynk.begin(auth, "Nazwa", "Hasło"); // Nazwa i hasło sieci WIFI
sensors.begin();
timer.setInterval(1000L, brama); //Sprawdzanie stanu
timer.setInterval(2000L, temperatura); //Sprawdzanie stanu
void temperatura()
  delay(5);
Blynk.virtualWrite(V1,sensors.getTempCByIndex(0)); //Pin wirtualny do temperatury
void brama()
if(digitalRead(pin) == 1){
  led1.on();
else{
  led1.off();
