Re MLX90614 from Melexis
Will you be supporting the MLX90614 from Melexis on a arduino.I have a longstanding project that I never managed to finish that uses this sensor to detect clouds as part of a astrophotography setup.Where I get stuck is to use the data to wake me up should the clouds roll in.A smart phone already has the alarm functionality so it would be great to finally get these two working together
Blynk supports any sensor that you plug into Arduino. If it has some specific library to process incoming data, then you actually write the same code that you would normally write. After that you’ll have to add a couple of Blynk code lines to push the data to the your smartphone.
