Raspberry Pi
Just Curious. Has anyone implemented blynk with the raspberry pi through an adapted code?
It’s already working with Raspberry Pi’s GPIOs :wink:
  • you should be able to run server locally from Raspberry Pi.
Dmitriy, what OS can we run the server from? I’m assuming one where we can code / type commands.
@Kamesan
Server is on java. So you can run it anywhere where java could be run. The bunch of OSes is pretty huge. For instance: http://www.oracle.com/technetwork/java/javase/config-417990.html#os. And this is not full list.
